911/914-6 regulator wiring ugh |
mb911 |
Jun 22 2024, 01:55 PM
914 Guru Group: Members Posts: 6,978 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
mb911 |
Jun 25 2024, 10:40 AM
@superhawk996 so interesting enough with no fuel pump running there is no voltage loss. Gonna change out the ignition switch to be sure might need a relay on the pump
Superhawk996 |
Jun 25 2024, 10:58 AM
914 Guru Group: Members Posts: 6,020 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
@superhawk996 so interesting enough with no fuel pump running there is no voltage loss. Gonna change out the ignition switch to be sure might need a relay on the pump Good find I can’t remember how much current fuel pump draws but should only be a couple amps - let’s say 5 amps? To get 1v of voltage drop across wiring would mean you have wiring with 0.2 ohms of resistance in it. Agree ignition switch is a good 1st place to look but if it’s not there, you’ll need to track it back to wherever it resides. Worst case is that it’s a few smaller drops across wiring, terminal connections etc. Is your fuel pump re-wired or are you running it off the relay board and OEM round relay back in engine compartment. Can’t remember what you did for the /6 conversion. |
mb911 |
Jun 25 2024, 11:16 AM
@superhawk996 so interesting enough with no fuel pump running there is no voltage loss. Gonna change out the ignition switch to be sure might need a relay on the pump Good find I can’t remember how much current fuel pump draws but should only be a couple amps - let’s say 5 amps? To get 1v of voltage drop across wiring would mean you have wiring with 0.2 ohms of resistance in it. Agree ignition switch is a good 1st place to look but if it’s not there, you’ll need to track it back to wherever it resides. Worst case is that it’s a few smaller drops across wiring, terminal connections etc. Is your fuel pump re-wired or are you running it off the relay board and OEM round relay back in engine compartment. Can’t remember what you did for the /6 conversion. I am not using a relay at all so just switched 12v but with switching to the 044 pump it maybe necessary now |
Superhawk996 |
Jun 25 2024, 11:31 AM
@superhawk996 so interesting enough with no fuel pump running there is no voltage loss. Gonna change out the ignition switch to be sure might need a relay on the pump Good find I can’t remember how much current fuel pump draws but should only be a couple amps - let’s say 5 amps? To get 1v of voltage drop across wiring would mean you have wiring with 0.2 ohms of resistance in it. Agree ignition switch is a good 1st place to look but if it’s not there, you’ll need to track it back to wherever it resides. Worst case is that it’s a few smaller drops across wiring, terminal connections etc. Is your fuel pump re-wired or are you running it off the relay board and OEM round relay back in engine compartment. Can’t remember what you did for the /6 conversion. I am not using a relay at all so just switched 12v but with switching to the 044 pump it maybe necessary now Got it. Yeah would definitely want that “battery” side of the D+ feed circuit to be reflecting full battery voltage over at the Gen light bulb (yellow highlighted wiring) |
Lo-Fi Version | Time is now: 30th June 2024 - 03:30 AM |
