New owner with few questions, Brake light always on! |
PaIsa |
Jun 13 2024, 05:17 AM
Member Group: Members Posts: 52 Joined: 13-June 24 From: Quebec, Canada Member No.: 28,180 Region Association: Canada |
Hello! New 914 owner here with a few questions.
First the car: 1.7 (I think) 1972 914 with carburetor, Irish Green resprayed. The issues: 1. Brake lights are always on. As soon as we put the key switch to ON, the rear brake lights come on even without touching the brake pedal. Looked at all the bulbs and everything is fine. Looked at wiring; did a repair on the front left ground wire but the rest seems OK. Looked at the switch on the master cylinder; it is there, but not sure what to look for. Any idea as to where to look to try to solve this. 2. Vibration: We have a steering wheel vibration when cruising at around 90-100 km/h. Where should I look first: wheel balancing? 3. Speedo not working: Our speedo is not working but I think that our issue is at the back of the car. We have a small tranny oil leak that seems to come from the speedo gear set-up. I did not open it yet but I guess that a first test that I should do would be to take the cable off, put the car in gear and see if the system for the speedo actually works. Would be all for now. Thanks |
PaIsa |
Jun 14 2024, 05:48 AM
For the brake light, turned out to be the switch at the pedal base that was not fitted properly. I had to adjust it slightly with the screw and very slightly bend the metal part for it to actually touch what seems to be a large washer so that it activates or not when we step on the pedal.
Will look at the speedo meter stuff this week end. |
emerygt350 |
Jun 14 2024, 12:08 PM
Advanced Member Group: Members Posts: 2,403 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
For the brake light, turned out to be the switch at the pedal base that was not fitted properly. I had to adjust it slightly with the screw and very slightly bend the metal part for it to actually touch what seems to be a large washer so that it activates or not when we step on the pedal. Will look at the speedo meter stuff this week end. wobble could be poor tires. Just rotate them to the back and see if it changes. And welcome to the forum! |
PaIsa |
Jun 25 2024, 12:47 PM
And welcome to the forum! [/quote] I swapped the tire front to back and it solved the vibration. Much more enjoyable now! Tires seem good quality but a bit bigger then stock. I will have them balanced at the end of the season. Just went to pick up part for the speedo/tranny dripping fix. Will look at getting this installed in the upcoming week. As well, I had to replace the alternator belt after I had the red light coming on in the dash. Found all the information needed in the forum! Thanks all! |
Lo-Fi Version | Time is now: 18th September 2024 - 07:14 PM |
