> Big six engine choice impressions, My favorite was surprising
davehg
post Jun 25 2024, 11:52 PM
Over the past eight years, I've had the chance to spend quality time in a number of big six conversions, including a 2.7, a 3.0, a 3.2, and a 3.6. I currently own two 914's with a 2.7 twin plug and a 3.2 chipped motor, and recently had an RS2.7 MFI engine completed for my 74 911s that formerly housed its original 2.7 CIS engine (now crated).
I've formed strong opinions. I'm a big believer that for a street car, the engine should fit the character of the 914 while still providing that something special that a bigger displacement engine gives. So here goes:
Let's start at the top of the displacement heap - the 3.6. It's a beast of a motor, and it renders the 901 a challenge to use (and greatly adds to the expense if fitting a 915 or something else). You effectively need to start in 2nd to quickly accelerate if using the 901, and even with a limited slip, it can overwhelm the balance of 914. On a track, this motor would be so much fun in the straights, but around town it does tend to dominate the 914 even when fitted with wide grippy tires, so you have to drive with more care when getting on it in the twisties. It also tends to make you lazier in keeping up momentum because you have the motor's torque and HP to fall back on. If you want to build the most bad ass streetable 914 GT monster and have plenty of disposable income, the 3.6 is where you start.
The 3.2 fares a bit better on overall driveability. While first gear is mostly unusable unless you want to gamble, it has terrific torque in 2-4th and would be my first choice for an autocross focused car because the torque and power down low are so usable. Plus, a stock 3.2 needs precious little tweaking (maybe a chip) to achieve decent HP numbers (e.g. 220). Sure you can hop it up to a wild twin plug PMO build, or if you feel especially financially irresponsible, do one of the new ITB/crankfire builds like I saw at the Air & Water EMPI booth, can get even more power. But like a 3.6, a 3.2 build will start adding up fast, and you're having to deal with bigger brakes, better cooling, and potentially chassis stiffening and suspension upgrades. Still, I get why this is a popular engine and I love mine as it lets me do things I couldn't do in my 2.7 (whether I should do them is another question).
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-21443-1719381164.1.jpg)
The 3.0 is interesting - to me it's the "Jan Brady" of engines - less power and less tweakable than a 3.2 but less expensive and considered more stout than the stock 2.7. IMHO it's quick but it lacks the full torquey grunt of the 3.2, doesn't quite have the excitement at the top of redline, and takes lots of additional $$$ to build into something that would just equal a chipped 3.2. Admittedly I've not spent as much time in a 3.0 but I get why they are popular alternatives to bigger flat sixes, and it's a very responsible choice if you're not doing a gonzo build.
Which brings me to the lowly (and wrongly but much maligned IMHO) 2.7. A stock 2.7 puts out 170hp max, and while it's fun and quick, it's not fast. In stock CIS form it has a limited torque range, and it makes more noise without delivering much pull above 5k. It was pleasant enough in my 911s but the best I could say was that it delivered a pleasant touring feel and great MPGs. After less than year, I quickly determined I needed more grunt.
Which brings me to the twin plug 2.7: with a solex grind cam and Webers (or PMOs) this is such a lovely engine. It absolutely fits the character of an early 914 - it has personality, grunt, it revs past 7k and howls like a banshee all the way there. Below 5k it delivers nice torque even from down low. Driving on twisty roads, it is perfectly happy between 3-5k where it pulls hard out of corners. Yes, it may need additional machine shop work at the outset, but even factoring in those costs, it's still a relative bargain compared to its bigger brothers - and you have lots of choices on cams and pistons to achieve either a nice low to mid torquey motor with a solex cam or a screamer with high compression pistons and S style cams. And with a front oil cooler, shuffle pin and other mods, you won't suffer the ills that the smog choked 75-77 motors suffered. You'll just cry once at the machine shop.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-21443-1719381165.2.jpg)
Here's why I think a built 2.7 best fits the authenticity of the 914 - Personality! You have to work it to keep up with the bigger sixes but it lets you carry momentum through the turns better, and it sings to you all the way to redline. The main culprit I'm finding is fuel efficiency, as I'm getting maybe 15-16mg whomping it where the 3.2 turns closer to 20 mpg (and the stock CIS can deliver as much as mid 20s). And then there's the extra cost of twin plug setups, which while cheaper than an MFI setup, still add up.
I'm still early days enjoying the RS2.7 MFI build in my 1974 911, but I think even with limited seat time, it's quickly become my ultimate favorite 2.7 for a street car. The payoff of the MFI is immediate acceleration, nearly flat torque through the entire RPM range, with linear power delivery that starts strong and just continues to build. The gorgeous soundtrack and Swiss watch feel of the motor are the stuff of air cooled dreams and I finally understand the love for the 1973 RS2.7 Carrera. Plus you can easily see 230-240hp if you invest even more for a higher compression build (I had seat time in a high compression 3.0 MFI build that bowled me over).
Problem is it's very cost prohibitive to build and MFI engine starting from scratch. Nothing is cheap with an MFI, and it takes special know how to tune and tweak unlike the relative ease of a PMO. Aside from expense, the MFI does punish you with 12mpg average when pushing hard. But if I had only one engine I was able to put in my 914 without worry of cost, the RS2.7 MFI might be it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-21443-1719381165.3.jpg)
Which brings me to a special 3.0 RSR build that I had the pleasure of getting a brief ride in. With MFI and high compression pistons, it was close to 330hp and had an 8k redline. It was the most glorious sound and feel I've ever experienced in a 914 (and that included a 2.5 short stroke carb'd motor below from the same engine builder that had me salivating the first time I rode along). Both of those cars were track focused cars with license plates, and I wouldn't consider them streetable or livable for day to day. But they were sure amazing and they live in my 914 dreams with their sound and character.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-21443-1719381165.4.jpg)
So there - I said it - I think the 2.7 of the bigger six motors, best fits the 914's character on the street, and price wise may be the best bang for the buck (assuming you've got a good block to start with). I'm ignoring the 2.3 and 2.4 which aren't big sixes though I know they can make some healthy numbers, and I've yet to experience a 2.8 or 2.9 build.
Big thanks to Bernd Buschen who made all these engine experiences (save for the 3.6) possible.
What's been your experience/opinion on the big sixes?
gereed75
post Jun 26 2024, 10:13 AM
Really interesting to hear these insights. I am running a 2.4 S spec carbed motor with Mod Solex cams in a narrow body original six. I have never had the experience of a truly big six.
Two things jump out at me reading this thread.
One is the mention of character. As the motors get bigger and tires get fatter (ie flares), I think you might begin to loose some of that sporty light weight fast rev feeling. At some point the motor has to start to dominate the character of the car. Not saying that is bad, just different.
The second is the feel of that engine behind your head. The sound, the mechanical noise all is pretty sublime. Best way to enjoy an air cooled flat six short of a 910. The 911 experience is fine, but more isolated and GT vice pure sport
My vote for dream shot motor is a short stroke 2.4 MFI. Some here have done it. Must be incredible!
davehg   Big six engine choice impressions   Jun 25 2024, 11:52 PM
930cabman   I am very new to this and just getting my basicall...   Jun 26 2024, 04:59 AM
Freezin 914   What a nice write up, I enjoyed reading through it...   Jun 26 2024, 04:59 AM
914Sixer   Good information because the average 914 guy is no...   Jun 26 2024, 06:10 AM
mlindner   Davehg, thats great information and assessment. I ...   Jun 26 2024, 07:00 AM
sixaddict   Fun read….. and did not have to spend big bucks ...   Jun 26 2024, 07:33 AM
JmuRiz   This is relevant to my interests, I took a 2.7 CIS...   Jun 26 2024, 08:18 AM
infraredcalvin   Thanks for that assessment, I’m struggling in bu...   Jun 26 2024, 08:27 AM
Shivers   That was great, Thanks   Jun 26 2024, 08:29 AM
gereed75   Really interesting to hear these insights. I am ru...   Jun 26 2024, 10:13 AM
davehg   My vote for dream shot motor is a short stroke ...   Jun 26 2024, 12:00 PM
mb911   My 2.4s with solex is awesome for how I use it. I ...   Jun 26 2024, 11:14 AM
SirAndy   I find my 3.6L very streetable and well behaved ar...   Jun 26 2024, 11:48 AM
mb911   I find my 3.6L very streetable and well behaved a...   Jun 26 2024, 11:58 AM
Steve   :agree: With all the opinions. My first six conv...   Jun 26 2024, 03:52 PM
Dr Evil   Spot on. I like the 2.7 for our cars in all of its...   Jun 26 2024, 04:26 PM
campbellcj   Great write-up and I've had a lot of fun with ...   Jun 26 2024, 04:58 PM
930cabman   Great write-up and I've had a lot of fun with...   Jun 27 2024, 04:52 AM
campbellcj   Great write-up and I've had a lot of fun wit...   Jun 27 2024, 07:33 AM
targa72e   Great comparison. Many do not have the advantage o...   Jun 26 2024, 11:18 PM
peteinjp   I certainly haven't had the opportunity to use...   Jun 27 2024, 05:08 AM
JmuRiz   hmmm sounds a lot like my build....I've wonder...   Jun 27 2024, 07:49 AM
slivel   hmmm sounds a lot like my build....I've wonde...   Jun 27 2024, 10:52 AM
gandalf_025   I was lucky enough to have my mechanic build a 2.5...   Jun 27 2024, 11:31 AM
davehg   Both my 3.2 and 2.7 914's have front mounted c...   Jun 27 2024, 01:55 PM
brant   My 2.1 uses two front coolers as well as the stock...   Jun 27 2024, 04:11 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 10:53 AM
