Villemi |
Newbie ![]() Group: Members Posts: 48 Joined: 7-January 20 From: France Member No.: 23,807 Region Association: France ![]() |
Hello,
We know on our D -Jetronic harness some male connectors 2,3,4,5 ways with female connectors with female pins inside. (IMG:http://www.914world.com/bbs2/uploads_offsite/i48.servimg.com-23807-1640445696.1.jpg) Do you know female connectors with male pins inside. ? I need your help because I want to use on my 914 Porsche a 123 ignition distributor. For the OEM distributor I have a 3 ways female connector and for the harness 3ways male connector I'd like to make a little harness with a 3 ways male on one side and 3 ways female connector on the other side It's easy to find male connectors with female pins but I don't find female connector with male pins. Do you know where I can find these parts ? The advantage of this little harness is if I have problems with the 123 ignition distributor I can use my OEM one without harness modification. Can you help me please ? PS: what is the item number of these D-Jetronic connectors ? Best regards Michel |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,583 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Rick, Brian, Jim,
Ill be meeting with Fiacra to do a prototype build then will reach out to you for yours. Thanks for your interest. This wiring connection seems to be a significant issue with the 123s, but is resolvable. @gonzo54 @FlacaProductions @Jim C |
gonzo54 |
Orange Crush ![]() ![]() Group: Members Posts: 229 Joined: 10-May 19 From: Seal Beach, CA Member No.: 23,112 Region Association: Southern California ![]() ![]() |
Rick, Brian, Jim, Ill be meeting with Fiacra to do a prototype build then will reach out to you for yours. Thanks for your interest. This wiring connection seems to be a significant issue with the 123s, but is resolvable. @gonzo54 @FlacaProductions @Jim C Thanks, been very happy with your harness- |
Lo-Fi Version | Time is now: 4th July 2024 - 03:13 AM |
