1.7 Rebuild First Start Up Advice, 1.7 Start Up on stand |
Robroe |
Jul 4 2024, 05:15 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Have 73 1.7 bought in pieces. Engine has been rebuilt and ‘souped up’ however I don’t know what internals were installed. New crank, cam, pistons, rods and heads. but I don’t know which ones. Weber 44 idf carbs. Never had oil in it and been stored unstarted for 10 yrs in climate control. I’ve added oil by slow dripping 2 quarts through the oil pressure sensor hole. Oil dripped out of the rockers so I’m pretty sure it got some oil as pre lube. It’s on a home built test stand with the transmission mounted with the starter.
I’m trying to turn the engine over by hand with the plugs out. Have squirted oil in each plug hole. I’m able to turn the engine by hand about 45 degrees and it gets harder to spin so can’t go any further. Would it be a good idea to pull the rocker arms to see if the builder installed some wild cam without checking valve/piston clearance? It doesn’t feel like internals are hitting each other but who knows? Would hate to pull the heads if I don’t have to. Any thoughts before I break something? Rob Roe Newbie |
emerygt350 |
Jul 6 2024, 05:10 AM
Advanced Member Group: Members Posts: 2,403 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I wouldn't worry about oil pressure yet but it couldn't hurt with the rockers off.
The springs are a little worrisome to me. I know they are used but I wonder if that means there is some radical cam in there. Do you have a micrometer? Measuring the lift on the cam might be interesting. You should be able to ballpark it with the pushrod travel. To determine if it's the valve springs you could put them back on one intake valve and try turning it by hand. If that works add another and keep going. If it gets progressively more difficult but the engine keeps turning... |
Lo-Fi Version | Time is now: 18th September 2024 - 07:08 PM |
