MPS Mapping, How and what info do you want? |
FlacaProductions |
May 30 2024, 01:06 PM
Senior Member Group: Members Posts: 1,733 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Many of you may remember my 123 Distributor install that finally worked out.
(here: http://www.914world.com/bbs2/index.php?sho...370332&hl=) I now have a vacuum pump and multi meter - TELL ME WHAT YOU WANT TO SEE. Unit is an 041 and has obviously been cracked open - before my time. It's marked with a Sharpie "74-76 2.0" which I believe is incorrect and should be for a 71-72 1.7. Maybe this accounts for the opening and potential adjustment. Currently holds 15in pretty much indefinitely and I get 93ohms between pins 7 and 15, and 344ohms between pins 8 and 10. All that seems pretty much right on - but it would NOT start after putting in the 123. Prior to the 123, it ran "fine" but then started running warm due to a distributor vacuum issue (more in another thread) Distributor was an 011 with a Pertronix Igniter II. Installed a "correct" 043 MPS and it fired right up and works great with the 123. Honestly - I'm just looking to acquire some database info for the World and then move this on, so if someone wants it, just yell. I have no idea what it's worth. |
ChrisFoley |
Jul 7 2024, 01:26 PM
I am Tangerine Racing Group: Members Posts: 7,958 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The diaphragm is an early one, just like the far left one in Jeff Bowlsby's picture. Maybe someone added the spacer. I'm guessing the differently staked hub assemblies were just how the factory made them at first.
Lo-Fi Version | Time is now: 18th September 2024 - 07:12 PM |
