MPS Mapping, How and what info do you want? |
FlacaProductions |
May 30 2024, 01:06 PM
Senior Member Group: Members Posts: 1,733 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Many of you may remember my 123 Distributor install that finally worked out.
(here: http://www.914world.com/bbs2/index.php?sho...370332&hl=) I now have a vacuum pump and multi meter - TELL ME WHAT YOU WANT TO SEE. Unit is an 041 and has obviously been cracked open - before my time. It's marked with a Sharpie "74-76 2.0" which I believe is incorrect and should be for a 71-72 1.7. Maybe this accounts for the opening and potential adjustment. Currently holds 15in pretty much indefinitely and I get 93ohms between pins 7 and 15, and 344ohms between pins 8 and 10. All that seems pretty much right on - but it would NOT start after putting in the 123. Prior to the 123, it ran "fine" but then started running warm due to a distributor vacuum issue (more in another thread) Distributor was an 011 with a Pertronix Igniter II. Installed a "correct" 043 MPS and it fired right up and works great with the 123. Honestly - I'm just looking to acquire some database info for the World and then move this on, so if someone wants it, just yell. I have no idea what it's worth. |
r_towle |
Jul 7 2024, 02:19 PM
Custom Member Group: Members Posts: 24,623 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Back when I was tuning a specific car with a 2.4 liter to remain on Diet, I did learn a lot about the MPSs that exist, and did some parts swapping....I still have all of the iterations I tried..
I believe the diaphragms where the key difference...especially the Mercedes ones that reached up to 2.6/7 liters... The Volvo one seems a bit less bumpy/ridgy if I recall, so less ridges. When we had no spare parts...yah we stripped what we could find and made it work...with AF measurements and reading plugs as we went along....worked fine. I still have the Diet inline tester box... Bottom line..its not at all out of range to see a diaphragm from one MPS in another body....it was the only choice available at that time. Rich |
Lo-Fi Version | Time is now: 18th September 2024 - 07:16 PM |
