> 914 structure, How are they made?
Ace Le Count
post Jul 5 2024, 02:53 PM
Looking for 4712908713
Hi all, from what I understand, the longs are double thickness? Is it the same all the way through the car, as in the top, bottom, and sides of them? Just trying to understand how these cars are built. Photos would really help. Thanks!
nathanxnathan
post Jul 6 2024, 07:11 PM
Here are a few pics I have that show how it's layered. To use the terminology in the diagram, Auto Atlanta has a piece that includes the inside outer and outside outer already assembled/welded together. The outside outer is actually the inner wheel well.
https://www.ebay.com/itm/232571921636?chn=p...BoaAnr1EALw_wcB
On the outside the long is a separate piece just forward of the firewall. You can see here how there is a flap that overlaps both layers of the rear. I think I fudged them together at the top here which I don't think is actually correct. It all gets sandwiched together as the rear of the door jam comes together with it.
Here's a pic of the inside, the 1 piece that goes from the rear of the front fender past the firewall, and it's cut just forward of the front of the trunk
Tricky to remove rear of that as there's a double layer section that overlaps it just in front of the trunk.
And a shot of both layers of the inside which includes the lower seatbelt mounting point.
I wouldn't recommend doing it how I did here, to remove the inside with the outside still attached. I feel like it would go way smoother to build up the car from the inside out as most builds I've seen do it.
Ace Le Count
post Jul 7 2024, 06:56 PM
QUOTE(nathanxnathan @ Jul 6 2024, 08:11 PM) *
Thank you! This is the exact answer I was looking for! Thanks to everyone for their help!
Ace Le Count   914 structure   Jul 5 2024, 02:53 PM
Montreal914   That is quite a wide question but let me try to ex...   Jul 5 2024, 03:46 PM
Ace Le Count   That is quite a wide question but let me try to e...   Jul 5 2024, 04:49 PM
didenpx   [quote name='Montreal914' post='3154899' date='Ju...   Nov 25 2024, 08:50 AM
Ace Le Count   [quote name='Ace Le Count' post='3154918' date='J...   Nov 28 2024, 12:32 PM
JeffBowlsby   https://bowlsby.net/914/Classic/Sections.htm   Jul 5 2024, 04:10 PM
930cabman   Hi all, from what I understand, the longs are dou...   Jul 5 2024, 04:16 PM
windforfun   Wasn't this the first uni-body car to be sold ...   Jul 5 2024, 05:00 PM
930cabman   Wasn't this the first uni-body car to be sold...   Jul 5 2024, 05:51 PM
KELTY360   Wasn't this the first uni-body car to be sol...   Jul 5 2024, 09:49 PM
technicalninja   https://gizmodo.com/a-brief-history-of-unib...600%...   Jul 5 2024, 06:05 PM
930cabman   https://gizmodo.com/a-brief-history-of-unib...600...   Jul 5 2024, 06:30 PM
technicalninja   Beetle had a "pan" that got substantiall...   Jul 5 2024, 06:36 PM
technicalninja   This is a good thread to look through regarding st...   Jul 5 2024, 07:20 PM
friethmiller   This is a good thread to look through regarding s...   Jul 8 2024, 07:56 AM
nathanxnathan   Here are a few pics I have that show how it's ...   Jul 6 2024, 07:11 PM
Ace Le Count   Here are a few pics I have that show how it's...   Jul 7 2024, 06:56 PM
worn   Hi all, from what I understand, the longs are dou...   Jul 6 2024, 07:21 PM
930cabman   Hi all, from what I understand, the longs are do...   Jul 7 2024, 08:24 AM
didenpx   This is the cross section of the front part of ...   Dec 2 2024, 06:14 PM
brant   This is the cross section of the front part of...   Dec 2 2024, 06:47 PM
didenpx   @Brant I’m referring to the piece between the h...   Dec 2 2024, 06:56 PM
brant   Ok I see what your talking about   Dec 2 2024, 08:00 PM
doug_b_928   That piece is an extension of the wheel well and t...   Dec 2 2024, 09:23 PM
- Lo-Fi Version Time is now: 4th December 2024 - 08:11 PM
