1.7 Rebuild First Start Up Advice, 1.7 Start Up on stand |
Robroe |
Jul 4 2024, 05:15 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Have 73 1.7 bought in pieces. Engine has been rebuilt and ‘souped up’ however I don’t know what internals were installed. New crank, cam, pistons, rods and heads. but I don’t know which ones. Weber 44 idf carbs. Never had oil in it and been stored unstarted for 10 yrs in climate control. I’ve added oil by slow dripping 2 quarts through the oil pressure sensor hole. Oil dripped out of the rockers so I’m pretty sure it got some oil as pre lube. It’s on a home built test stand with the transmission mounted with the starter.
I’m trying to turn the engine over by hand with the plugs out. Have squirted oil in each plug hole. I’m able to turn the engine by hand about 45 degrees and it gets harder to spin so can’t go any further. Would it be a good idea to pull the rocker arms to see if the builder installed some wild cam without checking valve/piston clearance? It doesn’t feel like internals are hitting each other but who knows? Would hate to pull the heads if I don’t have to. Any thoughts before I break something? Rob Roe Newbie |
emerygt350 |
Jul 7 2024, 05:26 PM
Advanced Member Group: Members Posts: 2,403 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Hopefully it was just crazy compression and stiff springs....
Robroe |
Jul 8 2024, 02:40 PM
Hopefully it was just crazy compression and stiff springs.... Just measured stroke by inserting a rubber hose in the plug hole and turning engine by hand from bottom of piston stroke to top. It measured 3.95 inches stroke. That seems big compared to stock published stroke at 2.66 inches stroke. Is 3.95” stroke possible with a non stock crank? This is supposed to be a hot engine but adding 1.3” to stroke seems like a lot. Turns easy by hand now so loosening up. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:01 PM |
