1.7 Rebuild First Start Up Advice, 1.7 Start Up on stand |
Robroe |
Jul 4 2024, 05:15 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Have 73 1.7 bought in pieces. Engine has been rebuilt and ‘souped up’ however I don’t know what internals were installed. New crank, cam, pistons, rods and heads. but I don’t know which ones. Weber 44 idf carbs. Never had oil in it and been stored unstarted for 10 yrs in climate control. I’ve added oil by slow dripping 2 quarts through the oil pressure sensor hole. Oil dripped out of the rockers so I’m pretty sure it got some oil as pre lube. It’s on a home built test stand with the transmission mounted with the starter.
I’m trying to turn the engine over by hand with the plugs out. Have squirted oil in each plug hole. I’m able to turn the engine by hand about 45 degrees and it gets harder to spin so can’t go any further. Would it be a good idea to pull the rocker arms to see if the builder installed some wild cam without checking valve/piston clearance? It doesn’t feel like internals are hitting each other but who knows? Would hate to pull the heads if I don’t have to. Any thoughts before I break something? Rob Roe Newbie |
technicalninja |
Jul 9 2024, 07:24 AM
Senior Member Group: Members Posts: 1,825 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Tear down tip!
Keep everything in its originally installed position. I even watch the hardware for placement and direction/clocking. All the crap should be "indexed". If the lifters have ever run, they HAVE to stay on their respective cam lobes! When you're taking the dash out of a Prius (I know you're not doing this) the placement of every single screw is important. Put a long one where a short one should have gone and you can pierce an ECU. I once saw a 300ZX twin turbo PCM destroyed by a screw the owner put in the wrong place. $1800 mistake in 1998! Fastner placement can be CRITICAL I'll often use egg containers, biscuit pans to keep track of hardware. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:08 PM |
