1.7 Rebuild First Start Up Advice, 1.7 Start Up on stand |
Robroe |
Jul 4 2024, 05:15 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Have 73 1.7 bought in pieces. Engine has been rebuilt and ‘souped up’ however I don’t know what internals were installed. New crank, cam, pistons, rods and heads. but I don’t know which ones. Weber 44 idf carbs. Never had oil in it and been stored unstarted for 10 yrs in climate control. I’ve added oil by slow dripping 2 quarts through the oil pressure sensor hole. Oil dripped out of the rockers so I’m pretty sure it got some oil as pre lube. It’s on a home built test stand with the transmission mounted with the starter.
I’m trying to turn the engine over by hand with the plugs out. Have squirted oil in each plug hole. I’m able to turn the engine by hand about 45 degrees and it gets harder to spin so can’t go any further. Would it be a good idea to pull the rocker arms to see if the builder installed some wild cam without checking valve/piston clearance? It doesn’t feel like internals are hitting each other but who knows? Would hate to pull the heads if I don’t have to. Any thoughts before I break something? Rob Roe Newbie |
technicalninja |
Jul 9 2024, 06:28 PM
Senior Member Group: Members Posts: 1,825 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
You couldn't have any better markings than that!!!!!
The 44s are probably correct. If it's what I think it is it's MORE than 30K today. You should ALSO have a "Billy Bad Ass" exhaust with it. If it measures anything over 71 on stroke you NEED one! There's a pretty good one in the classifieds right now that might pair well with that motor. http://www.914world.com/bbs2/index.php?showtopic=370909 Looks like it's pending right now. It's the nicest 4-cylinder exhaust that has been in the classifieds in 18months... You have what I WANT to find. A hidden Raby motor (maybe)! You might have hit a "Grand Slam!" Be STUPID careful with the lifters. There is a chance they are ceramic or roller... |
Lo-Fi Version | Time is now: 18th September 2024 - 06:57 PM |
