Clutch pedal Stuck |
TonyVan |
Jul 10 2024, 09:00 AM
Newbie Group: Members Posts: 19 Joined: 3-December 07 From: San Jose, Ca Member No.: 8,412 Region Association: Northern California |
New to the 914 world. Appreciate all the help I received on my distributor problem.
Now to my new dilemma. After working on the distributor, I took the car for a Run. Drive fine. Came home and parked it in the car port and covered it up. Next day, I decide to go for another drive and the clutch pedal is hard as a rock and won’t budge. I jacked up the car and see that the cable runs under the headers. It seems to be wrapped in some heat proof tape but wondering if it’s possible for the rubber sheath to have melted and fused to the cable? Would be grateful for any testing procedures. Thanks, Tony |
76-914 |
Jul 10 2024, 09:12 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,608 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
remove the 2 11mm nuts that secure the cable at the clutch fork. If you can't push the clutch pedal or move the cable to & fro then you need to look at the the clutch pedal arm to see if you have free movement. If the pedal moves freely w/o the cable attached I would suspect the cable itself is frozen. Heat proof tape isn't what I'd use. Look at getting some fire sleeve for that area. (IMG:style_emoticons/default/beerchug.gif) https://www.aircraftspruce.com/catalog/pnpages/05-01839.php
Lo-Fi Version | Time is now: 18th September 2024 - 06:58 PM |
