Question for 914/6 oil tank/oil change, Does it need a supplemental way to drain? |
Krieger |
Dec 16 2011, 12:46 AM
Advanced Member Group: Members Posts: 4,781 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I have seen some of the members here adding ways to drain the oil tank. 911s have a tank drain, but their tanks are mounted fairly low in relation to the engine. The bottom of the 6 tank is close to being near the same height as the top of the engine caes. Won't the oil just run into the engine case?
Krieger |
Jul 9 2024, 07:38 PM
This is the solution I came up with. I ordered the factory oil lines from the the tank to the cooler. It came with a union. I had a face machined then drilled and tapped it for a drain plug. I drilled the plug so I could safety wire it.
930cabman |
Jul 10 2024, 01:02 PM
Advanced Member Group: Members Posts: 3,874 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
This is the solution I came up with. I ordered the factory oil lines from the the tank to the cooler. It came with a union. I had a face machined then drilled and tapped it for a drain plug. I drilled the plug so I could safety wire it. Thanks for chiming it, especially after several years ago. This is great information |
Lo-Fi Version | Time is now: 5th February 2025 - 05:58 AM |
