> 914World Classifieds Rules
> 914-6 PMS Engine Mount & Conversion Oil Tank, Patrick Motorsports New In Box Items
Vysoc
post Jul 2 2024, 07:12 PM
Vysoc
Hello,
Up for sale will be two separate items:
Item 1) Engine Carrier Mount - Porsche 914 Bulk Head to Porsche 6 Cylinder Engine Conversion. Utilizes Poly Urethane Bushings TIG Welded steel - Black Powder Coated Finish. 13.5 Lbs. Has option of welding in or bolting to existing chassis.
$350.00 + Shipping - SOLD
Item 2) 914-6 Conversion Oil Tank -
Fits all Porsche 914-4 & 914-6 Chassis. PMS's Re-Production is a copy of the original 914-6 Steel Oil Tank. Made of .120/1/8" Aluminum and TIG Welded - The tank includes a 30mm or 16AN Feed and 26mm or 12 AN fittings.
This tank is a direct replacement for the factory metal oil tanks that with age rust out from the inside. With this Aluminum Tank that problem is gone and the Aluminum Tank helps to cool the oil faster than the stock tank.
Also included is the Oil Filler Neck Kit -
Aluminum reproduction unit - for original or reproduction Porsche 914-6 Oil Tank - Includes Stainless Steel Oil Level Dip Stick. Yellow Zinc plated seal cap. High quality silicone hose with stainless steel clamps.
Also included is the Oil Filter Console -
Billet Aluminum Black Anodized, includes hardware & O-Ring, uses late style Mahle OC-54 Oil Filter.
All three items for Oil Tank will be sold together.
$750.00 + Shipping
Please PM for any questions you may have about either of these items.
Thank you,
Vysoc
MikeV914
post Jul 10 2024, 03:03 PM
I'm new here ...
Hello,
Sent you a PM on the engine mount
Mike
- Lo-Fi Version Time is now: 15th January 2025 - 08:58 AM
