Question for 914/6 oil tank/oil change, Does it need a supplemental way to drain? |
Krieger |
Dec 16 2011, 12:46 AM
Advanced Member Group: Members Posts: 4,781 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I have seen some of the members here adding ways to drain the oil tank. 911s have a tank drain, but their tanks are mounted fairly low in relation to the engine. The bottom of the 6 tank is close to being near the same height as the top of the engine caes. Won't the oil just run into the engine case?
Krieger |
Jul 9 2024, 07:43 PM
I am very happy I did this. It drains very quicky and isn't messy like disconnecting fittings. I use an aluminum washer from the valve cover as a sealing ring.
porschetub |
Jul 10 2024, 04:12 PM
Advanced Member Group: Members Posts: 4,766 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I am very happy I did this. It drains very quicky and isn't messy like disconnecting fittings. I use an aluminum washer from the valve cover as a sealing ring. Exactly what I did ,used a NPT (?) 1/8" plug as mentioned works well ,I found I got more oil out once it was warm and drained quicky after stopping engine ,seemed I had less to drain from the engine that way ,cheers. |
Lo-Fi Version | Time is now: 5th February 2025 - 06:03 AM |
