1.7 Rebuild First Start Up Advice, 1.7 Start Up on stand |
Robroe |
Jul 4 2024, 05:15 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Have 73 1.7 bought in pieces. Engine has been rebuilt and ‘souped up’ however I don’t know what internals were installed. New crank, cam, pistons, rods and heads. but I don’t know which ones. Weber 44 idf carbs. Never had oil in it and been stored unstarted for 10 yrs in climate control. I’ve added oil by slow dripping 2 quarts through the oil pressure sensor hole. Oil dripped out of the rockers so I’m pretty sure it got some oil as pre lube. It’s on a home built test stand with the transmission mounted with the starter.
I’m trying to turn the engine over by hand with the plugs out. Have squirted oil in each plug hole. I’m able to turn the engine by hand about 45 degrees and it gets harder to spin so can’t go any further. Would it be a good idea to pull the rocker arms to see if the builder installed some wild cam without checking valve/piston clearance? It doesn’t feel like internals are hitting each other but who knows? Would hate to pull the heads if I don’t have to. Any thoughts before I break something? Rob Roe Newbie |
emerygt350 |
Jul 10 2024, 06:56 PM
Advanced Member Group: Members Posts: 2,403 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
First of all, looks like 2.0 heads to me. Cylinders look like iron but I could be wrong. The spacers under them are legion. I think you need to pull a head at this point just to know the valve size and deck height, but if I were you, I wouldn't crack the case. I know all the old fuddy duddies are going to tie their underwear in knots over that but if everything looks good up top, you can verify plenty of valve clearance (which you can do by pulling the head) and you can get a measure of the compression, I would have to ask myself if I could do better job than the last guy on the bottom end. Would I take it right out onto the track? No, I would carefully get it going and build up confidence in the previous person's build.
If you see everything looking like quality, I would go for it. But that is me. |
Robroe |
Jul 10 2024, 07:15 PM
First of all, looks like 2.0 heads to me. Cylinders look like iron but I could be wrong. The spacers under them are legion. I think you need to pull a head at this point just to know the valve size and deck height, but if I were you, I wouldn't crack the case. I know all the old fuddy duddies are going to tie their underwear in knots over that but if everything looks good up top, you can verify plenty of valve clearance (which you can do by pulling the head) and you can get a measure of the compression, I would have to ask myself if I could do better job than the last guy on the bottom end. Would I take it right out onto the track? No, I would carefully get it going and build up confidence in the previous person's build. If you see everything looking like quality, I would go for it. But that is me. Magnet sticks to cylinders so definitely not aluminum. |
Lo-Fi Version | Time is now: 18th September 2024 - 06:15 PM |
