Clutch pedal Stuck |
TonyVan |
Jul 10 2024, 09:00 AM
Newbie Group: Members Posts: 19 Joined: 3-December 07 From: San Jose, Ca Member No.: 8,412 Region Association: Northern California |
New to the 914 world. Appreciate all the help I received on my distributor problem.
Now to my new dilemma. After working on the distributor, I took the car for a Run. Drive fine. Came home and parked it in the car port and covered it up. Next day, I decide to go for another drive and the clutch pedal is hard as a rock and won’t budge. I jacked up the car and see that the cable runs under the headers. It seems to be wrapped in some heat proof tape but wondering if it’s possible for the rubber sheath to have melted and fused to the cable? Would be grateful for any testing procedures. Thanks, Tony |
TonyVan |
Jul 10 2024, 08:44 PM
I sent a long reply to all that offered hints. When I hit post, it gave a data base error and I lost the whole thing.
Abbreviation of post: No fluid in the pedal area and fluid level is good. Pedal box doesn’t look like it needs attention but I’ve rebuilt many. Ground strap removed, cleaned and tightened. But it was fine. Will check out the access front tunnel. Springs were shorter than the position of the end cap. Corrected and wired to hold. Thanks all! |
Lo-Fi Version | Time is now: 18th September 2024 - 06:17 PM |
