1.7 Rebuild First Start Up Advice, 1.7 Start Up on stand |
Robroe |
Jul 4 2024, 05:15 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Have 73 1.7 bought in pieces. Engine has been rebuilt and ‘souped up’ however I don’t know what internals were installed. New crank, cam, pistons, rods and heads. but I don’t know which ones. Weber 44 idf carbs. Never had oil in it and been stored unstarted for 10 yrs in climate control. I’ve added oil by slow dripping 2 quarts through the oil pressure sensor hole. Oil dripped out of the rockers so I’m pretty sure it got some oil as pre lube. It’s on a home built test stand with the transmission mounted with the starter.
I’m trying to turn the engine over by hand with the plugs out. Have squirted oil in each plug hole. I’m able to turn the engine by hand about 45 degrees and it gets harder to spin so can’t go any further. Would it be a good idea to pull the rocker arms to see if the builder installed some wild cam without checking valve/piston clearance? It doesn’t feel like internals are hitting each other but who knows? Would hate to pull the heads if I don’t have to. Any thoughts before I break something? Rob Roe Newbie |
Superhawk996 |
Jul 11 2024, 07:27 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
So lighter than OEM con rods. Looking good.
Pistons and cylinders from AA Performance Products. Budget oriented parts vs the big names but nothing wrong with their stuff at all - lots of folks using them. Mahle style slipper coating on the skirts is a nice touch. Decent amateur build based on what we’ve seen. Did you measure stroke? |
Lo-Fi Version | Time is now: 18th September 2024 - 07:24 PM |
