How alternator light works, a more detailed description |
Tom |
May 3 2014, 01:30 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
After reading many accounts of how this circuit works, I felt compelled to investigate further as I did not understand how two positives would cause a light to operate. They won't. One must be somewhat negative to complete the circuit. Internet searches turned up the same basic explanation, still was not buying it. I think it was being oversimplified.
This is how I think the alt light works: When the key is on and engine not running, there is 12 volts + at the alt light power side coming from the fused side of fuse #9. The other side goes to a junction on the relay board with D+. With the key to off and a meter connected between D+ and ground at the relay board, the reading is 12 ohms. As soon as the key is turned to on, the reading jumps to 12.5 meg ohms and the light comes on. If the wire for D+ to the alt is removed, the reading stays the same and the light stays on. Removing the VR caused the reading to jump to infinity and the light goes out. For the light to work, there has to be power to one side of the light and some resistance reading to ground for the other. Looking at the wiring diagram, one can follow the blue wire to the junction at the relay board at D+, then up thru the VR to a set of relay contacts, then down thru a ( resistor ?, not sure) and then down to the DF connection and on to the rotor where the current will produce a magnetic field. After the rotor, it goes to ground. When the alt spins enough RPM's, a voltage is produced and fed back to the VR, causing the relay to open and removes the ground path for the alt light. I could be entirely wrong here, but this is what I see and my readings more or less confirm it. If you see an error in my thinking, please post and let me know. Thanks, Tom Attached thumbnail(s) |
ClayPerrine |
Jul 12 2024, 05:32 AM
Life's been good to me so far..... Group: Admin Posts: 15,806 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
This sounds like an issue with bad grounds.
Was the ground wire that connects the back of the alternator to the case present and in good condition? |
930cabman |
Jul 12 2024, 05:38 AM
Advanced Member Group: Members Posts: 3,523 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
This sounds like an issue with bad grounds. Was the ground wire that connects the back of the alternator to the case present and in good condition? Yes, clean and tight The GEN light does not come on in any scenario. I will dig into this as I sense the issue lies with "bootstrapping" whatever that is |
87m491 |
Jul 12 2024, 06:30 AM
Member Group: Members Posts: 295 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Not for nothing, but unless I missed it you have not said the gen light bulb was present/connected/not burned out?
Lo-Fi Version | Time is now: 18th September 2024 - 06:19 PM |
