1.7 Rebuild First Start Up Advice, 1.7 Start Up on stand |
Robroe |
Jul 4 2024, 05:15 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Have 73 1.7 bought in pieces. Engine has been rebuilt and ‘souped up’ however I don’t know what internals were installed. New crank, cam, pistons, rods and heads. but I don’t know which ones. Weber 44 idf carbs. Never had oil in it and been stored unstarted for 10 yrs in climate control. I’ve added oil by slow dripping 2 quarts through the oil pressure sensor hole. Oil dripped out of the rockers so I’m pretty sure it got some oil as pre lube. It’s on a home built test stand with the transmission mounted with the starter.
I’m trying to turn the engine over by hand with the plugs out. Have squirted oil in each plug hole. I’m able to turn the engine by hand about 45 degrees and it gets harder to spin so can’t go any further. Would it be a good idea to pull the rocker arms to see if the builder installed some wild cam without checking valve/piston clearance? It doesn’t feel like internals are hitting each other but who knows? Would hate to pull the heads if I don’t have to. Any thoughts before I break something? Rob Roe Newbie |
technicalninja |
Jul 12 2024, 05:08 PM
Senior Member Group: Members Posts: 1,825 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Good looking numbers!
I'd pick a single shim to reduce deck height to .040. I've always balanced my pistons and rods myself. The machine shop won't invest the time that I am willing to, and they are never as accurate. If you have a V configuration engine the machine shop needs the pistons/rods/rings/pins/clips to calculate "bob" weight. I still don't let them do the balancing of the above. If you're an inline or a boxer they machine shop does not need the above to balance the crank and I'm a HUGE believer in sending the absolute minimum parts to the machine shop. It's hard for them to lose stuff that you keep in your shop... Now, they DO NEED EVERYTHING that attaches to the crank. If they are doing a proper job, they will balance the crank first by itself and then add an item and rebalance (doing the metal reduction to the new addition only), add another part, and so on. This is time consuming. The quick and dirty way is to assemble it all and just balance it once... Both ways will give you the same result but the long way will allow you to replace a single part and effect the total out of balance the least amount. You also have the option to balance just that item and be near perfect. SO two ways to balance... One is the old school proper way One is the new "Get-er-done" varity that is far more common now |
Robroe |
Jul 12 2024, 06:25 PM
Good looking numbers! I'd pick a single shim to reduce deck height to .040. I've always balanced my pistons and rods myself. The machine shop won't invest the time that I am willing to, and they are never as accurate. If you have a V configuration engine the machine shop needs the pistons/rods/rings/pins/clips to calculate "bob" weight. I still don't let them do the balancing of the above. If you're an inline or a boxer they machine shop does not need the above to balance the crank and I'm a HUGE believer in sending the absolute minimum parts to the machine shop. It's hard for them to lose stuff that you keep in your shop... Now, they DO NEED EVERYTHING that attaches to the crank. If they are doing a proper job, they will balance the crank first by itself and then add an item and rebalance (doing the metal reduction to the new addition only), add another part, and so on. This is time consuming. The quick and dirty way is to assemble it all and just balance it once... Both ways will give you the same result but the long way will allow you to replace a single part and effect the total out of balance the least amount. You also have the option to balance just that item and be near perfect. SO two ways to balance... One is the old school proper way One is the new "Get-er-done" varity that is far more common now I need an engine stand yoke for my build. My welding table would be a fine bench mount. What engine stand combination due you use? Hate to spend $400 for a one time use. |
Lo-Fi Version | Time is now: 18th September 2024 - 06:52 PM |
