Shifter "centering" and accidental reverse, Update - fixed |
burlybryan |
Jun 3 2024, 03:57 PM
Member Group: Members Posts: 117 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
Since I've had my car (2020), it's always had a tendency to go from first straight up to reverse when shifting. Especially when cold. I've done all bushings from the firewall back, but I still have to be very careful when shifting from first to second. Shift from first requires a push out of first to let the shifter try to center, then carefully go up to second.
I haven't made any improvements to the shifter at the cabin. Are there similar bushings or a "centering spring" or something under the shifter than can be changed? All the focus seems to be on the firewall back, but I wondered if there is anything to prevent my reverse kiss tendencies at the shifter instead (besides the shiftee - me). Thanks. |
rgalla9146 |
Jul 5 2024, 11:40 AM
Advanced Member Group: Members Posts: 4,620 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Mark the splined shaft for depth and spline position.
Keep the current depth and rotate one spline either clockwise or CCW. Drive it. Better ? or worse ? if better go one more spline. IF worse go two splines in the opposite direction. You'll know when it is getting better. |
ChrisFoley |
Jul 13 2024, 04:29 AM
I am Tangerine Racing Group: Members Posts: 7,958 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Mark the splined shaft for depth and spline position. Keep the current depth and rotate one spline either clockwise or CCW. Drive it. Better ? or worse ? if better go one more spline. IF worse go two splines in the opposite direction. You'll know when it is getting better. With 36 splines, a movement of one spline is 10 degrees. Most of the time, the amount of rotation required to correct a misalignment is only a degree or two. Good thing there are no splines on the ID of the mating piece. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:15 PM |
