mwizard1 |
Newbie ![]() Group: Members Posts: 22 Joined: 25-May 24 From: N San Diego Co Member No.: 28,148 Region Association: None ![]() |
I think I saw somewhere that the lower mount for the front strut could be moved to improve handling. Any info on this?
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,925 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I think I saw somewhere that the lower mount for the front strut could be moved to improve handling. Any info on this? It’s for bump steer purposes That only comes into play if a car is lowered so much that the stock geometry of the suspension is compromised by lowering the car The modification is to correct the compromise of lowering By changing the steering arm On the bottom of the strut I’m less aware of modifications that would move or change Some use offset ball joints when trying to increase negative camber There are other things that can be done My strut housing were sectioned. And with custom race Kori’s that are shorter than stock to give back shock travel on a lowered car Get a performance oriented 4 wheel alignment with tires that are soft. Like 100 treadwear rated. And high end brake pads. You’ll enjoy that for a performance handling |
mwizard1 |
I think I saw somewhere that the lower mount for the front strut could be moved to improve handling. Any info on this? It’s for bump steer purposes That only comes into play if a car is lowered so much that the stock geometry of the suspension is compromised by lowering the car The modification is to correct the compromise of lowering I am building an autocross car so I will be lowering it a lot. Where can I get more info or parts? |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:27 AM |
