I feel like I need stickers on my air filter housing? |
mb911 |
Jul 12 2024, 05:45 AM
914 Guru Group: Members Posts: 7,149 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
ClayPerrine |
Jul 12 2024, 09:36 PM
Life's been good to me so far..... Group: Admin Posts: 15,806 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Why is there a dent in the back of the air cleaner?????
mb911 |
Jul 13 2024, 04:46 AM
Why is there a dent in the back of the air cleaner????? Only way it would fit so had to massage it. Spent a ton of time on this. I have the engine at stock 914-6 height but the air cleaner just was a PIA but I refused to go with k&n setups. I purchased a few housings but all from 911s and required modifications before the engine lid bracing would clear |
rgalla9146 |
Jul 13 2024, 05:59 AM
Advanced Member Group: Members Posts: 4,620 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Why is there a dent in the back of the air cleaner????? Only way it would fit so had to massage it. Spent a ton of time on this. I have the engine at stock 914-6 height but the air cleaner just was a PIA but I refused to go with k&n setups. I purchased a few housings but all from 911s and required modifications before the engine lid bracing would clear Ben I had the same question. The engine tin looks to be at the right height. Tall manifolds ? Phenolic spacers ? Did you try a 911 plastic housing ? |
mb911 |
Jul 13 2024, 06:51 AM
Why is there a dent in the back of the air cleaner????? Only way it would fit so had to massage it. Spent a ton of time on this. I have the engine at stock 914-6 height but the air cleaner just was a PIA but I refused to go with k&n setups. I purchased a few housings but all from 911s and required modifications before the engine lid bracing would clear Ben I had the same question. The engine tin looks to be at the right height. Tall manifolds ? Phenolic spacers ? Did you try a 911 plastic housing ? Phenolic spacers , standard manifolds off a 71 T, no never wanted plastic it just scared me when I was running fuel to the carbs but now that it’s fuel injected maybe. Yes for sure the proper height as you can see by sheet metal etc. |
ClayPerrine |
Jul 13 2024, 08:29 AM
Why is there a dent in the back of the air cleaner????? Only way it would fit so had to massage it. Spent a ton of time on this. I have the engine at stock 914-6 height but the air cleaner just was a PIA but I refused to go with k&n setups. I purchased a few housings but all from 911s and required modifications before the engine lid bracing would clear Ben I had the same question. The engine tin looks to be at the right height. Tall manifolds ? Phenolic spacers ? Did you try a 911 plastic housing ? Phenolic spacers , standard manifolds off a 71 T, no never wanted plastic it just scared me when I was running fuel to the carbs but now that it’s fuel injected maybe. Yes for sure the proper height as you can see by sheet metal etc. Weird.. When I put the 73 T motor in my car, I didn't have to alter the factory air cleaner at all. But it was MFI. |
mb911 |
Jul 13 2024, 10:39 AM
Why is there a dent in the back of the air cleaner????? Only way it would fit so had to massage it. Spent a ton of time on this. I have the engine at stock 914-6 height but the air cleaner just was a PIA but I refused to go with k&n setups. I purchased a few housings but all from 911s and required modifications before the engine lid bracing would clear Ben I had the same question. The engine tin looks to be at the right height. Tall manifolds ? Phenolic spacers ? Did you try a 911 plastic housing ? Phenolic spacers , standard manifolds off a 71 T, no never wanted plastic it just scared me when I was running fuel to the carbs but now that it’s fuel injected maybe. Yes for sure the proper height as you can see by sheet metal etc. Weird.. When I put the 73 T motor in my car, I didn't have to alter the factory air cleaner at all. But it was MFI. I wonder if the MFI air cleaners are shorter? The steel ones have no forgiving factors |
Lo-Fi Version | Time is now: 18th September 2024 - 07:02 PM |
