3rd Brake light behind targa trim |
Literati914 |
Jul 8 2024, 11:32 AM
Senior Member Group: Members Posts: 1,651 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I've got a couple extra horizontal targa trim (brightwork) pieces on hand and I ran extra wiring for a 3rd brake light during my wiring harness refurb. I was hoping to find a slim LED strip and neatly cut away some of the metal trim piece to fit it behind - for a clean simple look.
I've read up on 3rd brake lights here on the forum - so I know what all the other options are, and basically I'm not interested in doing any of those.. however, I'd consider mounting one on the outside face of the trim IF there was no way of getting it behind the trim.. but that's not ideal. Two things wrong with the ones I'm seeing w/ google searches.. they seem to be only adhesive mountable and that adhesive is on the backside obviously. I want a screw at each end if possible, so some kind of flange around the perimeter would be nice. Also, they tend to be way too long. I found an old post from @euro911 showing the set up, but it was just a pic, no details to it. Anyone done this and have any recommendations? . |
Literati914 |
Jul 13 2024, 11:47 AM
24 of stick on LED strip from Autozone. Run the wire under the chrome down to the brake lights. This is now 5-6 years old and still working. Drilled the center of the chrome strip and put in a rubber grommet for the wires. That’s what I should do. Very simple and ai have an extra trim piece That's probably about as simple as it's gonna get. So, no issues with the adhesive after it gets wet? I've played with the idea of getting a strip like this ^^ (cause they're probably gonna be the slimmest option), adhere it to a thin strip of metal that's longer than the cut-out opening, and the metal strip formed into a bracket shape. Then a sheetmetal screw on either side of the cut-out opening goes thru that LED adhered metal bracket, to hold it tight to the back of the cut opening. That way the LEDs are recessed. . |
Lo-Fi Version | Time is now: 18th September 2024 - 07:04 PM |
