> My 914-6 GT Tribute, low oil pressure when warned up.
mlindner
post Aug 18 2021, 06:47 AM
Every thing seems fine, start up, warm up all good oil pressure reading. But after a while at idle the oil pressure gauge is almost nothing. Running 20-50 valvaline for brake in. Should I go to straight 60 wt race oil. This car is mostly a track car, or when driven on the street it likes the 5 to 7,000 rpm range. Not a cold weather 914. Thanks, Mark
sixnotfour
post Aug 18 2021, 06:41 PM
Must be Racing Clearances ..Haha, general rule is 1 bar per 1k rpm,,we a carrera the othe day same way as yours,, But it has a ton of miles on it.Cut filter open and monitor,,at this point 20/50. Oil analysis.
Unknowns are always a gamble...Ask Eric Shea about his 2.5.. almost a total failure, before rebuild..really nasty rod bearings..
3 bar 4 bar oil pump ?? all makes a diff. ..shiny inst always best..
stownsen914
post Aug 18 2021, 08:46 PM
I believe 10 psi per 1000 RPM is the rule of thumb.
I think it's not uncommon for early motors to have essentially 0 oil pressure at idle. I recall my parents' 1970 911 did that when the oil was hot. Perhaps more likely if it has an early oil pump. Not saying it's ideal, mind you.
930cabman
post Jul 13 2024, 01:44 PM
QUOTE(stownsen914 @ Aug 18 2021, 08:46 PM) *
Another older thread, but the information does not change. Oil temp in the 180F range, green light is on solid at idle (1,000 rpms) and reading less than 10psi on a hard piped gauge. Fresh 2.7 with new bearings, etc, etc.
45psi at 3500 rpms when engine is warm
- Lo-Fi Version Time is now: 3rd April 2025 - 01:30 AM
