1.7 Rebuild First Start Up Advice, 1.7 Start Up on stand |
Robroe |
Jul 4 2024, 05:15 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Have 73 1.7 bought in pieces. Engine has been rebuilt and ‘souped up’ however I don’t know what internals were installed. New crank, cam, pistons, rods and heads. but I don’t know which ones. Weber 44 idf carbs. Never had oil in it and been stored unstarted for 10 yrs in climate control. I’ve added oil by slow dripping 2 quarts through the oil pressure sensor hole. Oil dripped out of the rockers so I’m pretty sure it got some oil as pre lube. It’s on a home built test stand with the transmission mounted with the starter.
I’m trying to turn the engine over by hand with the plugs out. Have squirted oil in each plug hole. I’m able to turn the engine by hand about 45 degrees and it gets harder to spin so can’t go any further. Would it be a good idea to pull the rocker arms to see if the builder installed some wild cam without checking valve/piston clearance? It doesn’t feel like internals are hitting each other but who knows? Would hate to pull the heads if I don’t have to. Any thoughts before I break something? Rob Roe Newbie |
technicalninja |
Jul 13 2024, 02:29 PM
Senior Member Group: Members Posts: 1,825 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Thanks for the pics!
Those ridges in the port say "CNC" ported. It ALMOST looks like the port is undercut just beyond the valve seat. That "flies in the face" of normal porting techniques... Most ports work best with throats at 85% of the seat diameter. Those throats look bigger than the seat! (IMG:style_emoticons/default/screwy.gif) Maybe it's a "Type4" type of thing... I'd love different angles and better shots of the exhaust port which I believe is the "Achilles Heel" of Type 4 head flow. The 2.0l heads I've messed with had pretty decent intakes and the VERY WORST exhaust ports I've seen. It didn't look like there was a decent way to "fix" the exhaust port IMO. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:11 PM |
