Anyone have photos of a -6 oil tank that's been cut open?... |
Detroit |
Jul 13 2024, 12:00 PM
Member Group: Members Posts: 70 Joined: 28-December 16 From: Detroit metro area Member No.: 20,709 Region Association: Upper MidWest |
So, I've just rebuilt a 911SC motor to put into my car. It's mounted in a start cart, and to cut a long story short, it has no oil pressure due to no oil coming out of the tank.
It sounds like a kazoo if I blow into that fitting, but I cannot suck anything out of it. I'd have thought that that fitting would open straight into the volume of the tank, but maybe there's a pipe in there that's collapsed?... Anyway, I'd like to understand exactly what it looks like there before doing anything drastic... This is, incidentally, a factory -6 tank. Thanks very much in advance! @mb911 Ben, I'm tagging you, because I figure if anyone on this site has cut a tank open, it'd be you... |
Superhawk996 |
Jul 13 2024, 12:57 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Attached thumbnail(s) |
fixer34 |
Jul 13 2024, 03:43 PM
Senior Member Group: Members Posts: 1,153 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
I saw this diagram on another thread and have a question. This shows the pressure relief valve exit as going to the pressure pump input and gravity/suction feed pipe on the tank. Shouldn't it be going to the tank return line? This would REALLY mess up a check valve on the supply line.. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:10 PM |
