Ground Points, Bare Metal Base Disk |
DennisV |
Jul 14 2024, 08:29 AM
Senior Member Group: Members Posts: 533 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Would I be correct in thinking that the metal disk where ground studs are located should be bare metal?
The one in this photo is above the relay board in the engine bay. It was painted body color and I stripped it with a wire brush. I just can't imagine that thick disk behind the stud was meant to be covered in paint if that is a ground location. P.S. After tightening these connections, is it good practice to coat them in dielectric grease? P.P.S. Are the ground point locations the same on the 914-6 as the 914-4s? @JeffBowlsby had a nice drawing of the locations, but I think it was specific to the 4s. |
technicalninja |
Jul 14 2024, 11:44 AM
Senior Member Group: Members Posts: 1,825 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
However, I've used dielectric grease on my terminals for years without a single issue. Doesn't make sense to me either. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) I'd love to find a "pro-electric" grease that had the same life span as dielectric grease. I AM POSITIVE that if you smear the crap out of your battery terminals with dielectric grease, to the point they're gooey and sticky, you can come back 4 years later, knock the dried hardened grease off and have perfect terminals... It works BETTER than any other anti-corrosion product I've tried, and I believe I've tried everything. Now, If @SuperHawk996 has a better suggestion I'm ALL EARS!!!! Because putting a non-conductive grease on electrical shit just sounds WRONG! |
Lo-Fi Version | Time is now: 18th September 2024 - 07:18 PM |
