Rear trunk lower latch, Picture needed |
TonyVan |
Jul 14 2024, 06:17 PM
Newbie Group: Members Posts: 19 Joined: 3-December 07 From: San Jose, Ca Member No.: 8,412 Region Association: Northern California |
Something new as a result of of my "Clutch Pedal Stuck" thread.
While dissembling the interior, I removed the seats and the padded panel behind them. I found that the trunk release pull handle does not unscrew. Figured I'd unhook it from the trunk latch. As you can probably guess, I closed the trunk that night after calling it a day and realized what I did the next morning. I got the trunk open but Im having a hard time visualizing the assembly of the lower latch. I see how the cable goes into the metal tube and up through the spring to the retaining pin, but what keeps the spring centered on the cable? Of course I've forgotten how it goes back together. Searched the forums (worst search program I've ever used") and found nothing. In fact, I think whatever I search for I get the same results! Anyway, If anyone has or can take a picture of the assembly, under the black plastic cover, I'd appreciate it. TOny |
bdstone914 |
Jul 14 2024, 11:22 PM
bdstone914 Group: Members Posts: 4,658 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Something new as a result of of my "Clutch Pedal Stuck" thread. While dissembling the interior, I removed the seats and the padded panel behind them. I found that the trunk release pull handle does not unscrew. Figured I'd unhook it from the trunk latch. As you can probably guess, I closed the trunk that night after calling it a day and realized what I did the next morning. I got the trunk open but Im having a hard time visualizing the assembly of the lower latch. I see how the cable goes into the metal tube and up through the spring to the retaining pin, but what keeps the spring centered on the cable? Of course I've forgotten how it goes back together. Searched the forums (worst search program I've ever used") and found nothing. In fact, I think whatever I search for I get the same results! Anyway, If anyone has or can take a picture of the assembly, under the black plastic cover, I'd appreciate it. TOny It sounds like you are describing the engine lid latch. You lost me a black plastic cover and assembling the latch. Can you show a picture of what parts you have? |
Lo-Fi Version | Time is now: 18th September 2024 - 06:58 PM |
