How alternator light works, a more detailed description |
Tom |
May 3 2014, 01:30 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
After reading many accounts of how this circuit works, I felt compelled to investigate further as I did not understand how two positives would cause a light to operate. They won't. One must be somewhat negative to complete the circuit. Internet searches turned up the same basic explanation, still was not buying it. I think it was being oversimplified.
This is how I think the alt light works: When the key is on and engine not running, there is 12 volts + at the alt light power side coming from the fused side of fuse #9. The other side goes to a junction on the relay board with D+. With the key to off and a meter connected between D+ and ground at the relay board, the reading is 12 ohms. As soon as the key is turned to on, the reading jumps to 12.5 meg ohms and the light comes on. If the wire for D+ to the alt is removed, the reading stays the same and the light stays on. Removing the VR caused the reading to jump to infinity and the light goes out. For the light to work, there has to be power to one side of the light and some resistance reading to ground for the other. Looking at the wiring diagram, one can follow the blue wire to the junction at the relay board at D+, then up thru the VR to a set of relay contacts, then down thru a ( resistor ?, not sure) and then down to the DF connection and on to the rotor where the current will produce a magnetic field. After the rotor, it goes to ground. When the alt spins enough RPM's, a voltage is produced and fed back to the VR, causing the relay to open and removes the ground path for the alt light. I could be entirely wrong here, but this is what I see and my readings more or less confirm it. If you see an error in my thinking, please post and let me know. Thanks, Tom Attached thumbnail(s) |
930cabman |
Jul 14 2024, 04:32 PM
Advanced Member Group: Members Posts: 3,523 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Excited
Still having an issue, but seems as though the alternator comes into charging earlier. I am still unable to get the GEN light to light under any condition (Lamp will light with 12v applied). Red/white wire has switched battery voltage. Blue wire I cannot get anything, no voltage, no continuity to ground, nothing. But, it seems as the system comes online quicker. Alternator was bench tested and was working according to my local rebuilder. Hate to source a new alternator, but kinda looking that might be the answer. |
Spoke |
Jul 15 2024, 08:23 AM
Jerry Group: Members Posts: 7,051 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Excited Still having an issue, but seems as though the alternator comes into charging earlier. I am still unable to get the GEN light to light under any condition (Lamp will light with 12v applied). Red/white wire has switched battery voltage. Blue wire I cannot get anything, no voltage, no continuity to ground, nothing. But, it seems as the system comes online quicker. Alternator was bench tested and was working according to my local rebuilder. Hate to source a new alternator, but kinda looking that might be the answer. Test the GEN light with ignition ON but engine not running. First pull out the instrument with the GEN light so both terminals are accessible. With ignition ON engine not running, measure the voltage to chassis on both sides of the GEN light. Then measure the blue wire coming out of the alternator. It too should be equal to one of the GEN light spades. Is the alternator bootstrapping earlier or do you just have the magic decoder ring (ie, blip the throttle) to get the alternator going? |
930cabman |
Jul 15 2024, 09:21 AM
Excited Still having an issue, but seems as though the alternator comes into charging earlier. I am still unable to get the GEN light to light under any condition (Lamp will light with 12v applied). Red/white wire has switched battery voltage. Blue wire I cannot get anything, no voltage, no continuity to ground, nothing. But, it seems as the system comes online quicker. Alternator was bench tested and was working according to my local rebuilder. Hate to source a new alternator, but kinda looking that might be the answer. Test the GEN light with ignition ON but engine not running. First pull out the instrument with the GEN light so both terminals are accessible. With ignition ON engine not running, measure the voltage to chassis on both sides of the GEN light. 12V with the red/white wire 0V with the light blue wire Then measure the blue wire coming out of the alternator. It too should be equal to one of the GEN light spades. Blue wire reads 0V, engine off or engine running Is the alternator bootstrapping earlier or do you just have the magic decoder ring (ie, blip the throttle) to get the alternator going? The decoder ring seems to be working fine, after a couple blips, she comes right online putting out about 14 or so volts. maybe I leave well enough alone |
Lo-Fi Version | Time is now: 18th September 2024 - 07:24 PM |
