How alternator light works, a more detailed description |
Tom |
May 3 2014, 01:30 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
After reading many accounts of how this circuit works, I felt compelled to investigate further as I did not understand how two positives would cause a light to operate. They won't. One must be somewhat negative to complete the circuit. Internet searches turned up the same basic explanation, still was not buying it. I think it was being oversimplified.
This is how I think the alt light works: When the key is on and engine not running, there is 12 volts + at the alt light power side coming from the fused side of fuse #9. The other side goes to a junction on the relay board with D+. With the key to off and a meter connected between D+ and ground at the relay board, the reading is 12 ohms. As soon as the key is turned to on, the reading jumps to 12.5 meg ohms and the light comes on. If the wire for D+ to the alt is removed, the reading stays the same and the light stays on. Removing the VR caused the reading to jump to infinity and the light goes out. For the light to work, there has to be power to one side of the light and some resistance reading to ground for the other. Looking at the wiring diagram, one can follow the blue wire to the junction at the relay board at D+, then up thru the VR to a set of relay contacts, then down thru a ( resistor ?, not sure) and then down to the DF connection and on to the rotor where the current will produce a magnetic field. After the rotor, it goes to ground. When the alt spins enough RPM's, a voltage is produced and fed back to the VR, causing the relay to open and removes the ground path for the alt light. I could be entirely wrong here, but this is what I see and my readings more or less confirm it. If you see an error in my thinking, please post and let me know. Thanks, Tom Attached thumbnail(s) |
930cabman |
Jul 15 2024, 04:25 PM
Advanced Member Group: Members Posts: 3,523 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Got it, mostly. As you can imagine this has been driving me crazy and today I worked backwards from the lt blue wire on the GEN light. I was not finding continuity from the GEN light to the socket on the relay board, but I was getting about 100 ohms from the D+ wire to ground at the alternator. I had the D+ wire from the alternator plugged into the wrong socket on the relay board. I found the correct socket with continuity and now the GEN light comes on when the key is on, engine off. When the engine starts the GEN light stays on for a couple seconds, then goes out and a voltmeter indicates 14V +/-
Another bridge crossed with this /6 conversion. BTW, she sounds great |
Superhawk996 |
Jul 15 2024, 05:02 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Got it, mostly. As you can imagine this has been driving me crazy and today I worked backwards from the lt blue wire on the GEN light. I was not finding continuity from the GEN light to the socket on the relay board, but I was getting about 100 ohms from the D+ wire to ground at the alternator. I had the D+ wire from the alternator plugged into the wrong socket on the relay board. I found the correct socket with continuity and now the GEN light comes on when the key is on, engine off. When the engine starts the GEN light stays on for a couple seconds, then goes out and a voltmeter indicates 14V +/- Another bridge crossed with this /6 conversion. BTW, she sounds great Good job. Good finds. (IMG:style_emoticons/default/smilie_pokal.gif) So this is where the bulb comes into play a higher wattage bulb will allow for higher excitation current and may turn off the light faster depending on what wattage is in there currently. 4 Watt is what the bulletin was trying to achieve. |
930cabman |
Jul 15 2024, 06:19 PM
Got it, mostly. As you can imagine this has been driving me crazy and today I worked backwards from the lt blue wire on the GEN light. I was not finding continuity from the GEN light to the socket on the relay board, but I was getting about 100 ohms from the D+ wire to ground at the alternator. I had the D+ wire from the alternator plugged into the wrong socket on the relay board. I found the correct socket with continuity and now the GEN light comes on when the key is on, engine off. When the engine starts the GEN light stays on for a couple seconds, then goes out and a voltmeter indicates 14V +/- Another bridge crossed with this /6 conversion. BTW, she sounds great Good job. Good finds. (IMG:style_emoticons/default/smilie_pokal.gif) So this is where the bulb comes into play a higher wattage bulb will allow for higher excitation current and may turn off the light faster depending on what wattage is in there currently. 4 Watt is what the bulletin was trying to achieve. Thank you, I was able to sneak away for a bit today and was determined, especially when my local rebuilder bench tested and gave it a thumbs up. I am good with a couple second delay before the GEN light goes out and it could need a different wattage bulb On to the next item |
Lo-Fi Version | Time is now: 18th September 2024 - 07:16 PM |
