Radio antenna whats best ?, 914 radio antenna |
porscheteck914 |
Jul 13 2024, 10:17 AM
Newbie Group: Members Posts: 38 Joined: 23-March 23 From: n.c. Member No.: 27,247 Region Association: North East States |
Hello Fellas , I want a electric retractable radio antenna for my 914 . What will work and fit without modifying inner fender ? Would like to go with a Hirschmann. A model 2024 ?? thank you !
FlacaProductions |
Jul 13 2024, 07:09 PM
Senior Member Group: Members Posts: 1,733 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I had an automatic antenna on my previous 73 and no matter what you go with, I would suggest putting a a manual switch on it. I found that it was very tall and stuck up quite a bit. With a manual switch you can limit how far it goes up. It was a long time ago, but I think I just put it in line with the control wire from the head unit - so when the unit tells it to go up, it goes up til you turn the switch off.
The alternative is to take the unit apart and cut the plastic toothed snake that is inside the antenna. Make it to your desired length. |
windforfun |
Jul 13 2024, 08:01 PM
Senior Member Group: Members Posts: 1,943 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
I had an automatic antenna on my previous 73 and no matter what you go with, I would suggest putting a a manual switch on it. I found that it was very tall and stuck up quite a bit. With a manual switch you can limit how far it goes up. It was a long time ago, but I think I just put it in line with the control wire from the head unit - so when the unit tells it to go up, it goes up til you turn the switch off. The alternative is to take the unit apart and cut the plastic toothed snake that is inside the antenna. Make it to your desired length. Why bother to fuck with it? Just leave it alone & if you're really hurting for something to do then read a book or play chess on your computer. Is this OCD or what? BTDT. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
FlacaProductions |
Jul 14 2024, 09:29 AM
I had an automatic antenna on my previous 73 and no matter what you go with, I would suggest putting a a manual switch on it. I found that it was very tall and stuck up quite a bit. With a manual switch you can limit how far it goes up. It was a long time ago, but I think I just put it in line with the control wire from the head unit - so when the unit tells it to go up, it goes up til you turn the switch off. The alternative is to take the unit apart and cut the plastic toothed snake that is inside the antenna. Make it to your desired length. Why bother to fuck with it? Just leave it alone & if you're really hurting for something to do then read a book or play chess on your computer. Is this OCD or what? BTDT. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) Why play chess or read a book when you can fuck with your car? Thanks for yet another pointless comment. |
windforfun |
Jul 15 2024, 07:08 PM
I had an automatic antenna on my previous 73 and no matter what you go with, I would suggest putting a a manual switch on it. I found that it was very tall and stuck up quite a bit. With a manual switch you can limit how far it goes up. It was a long time ago, but I think I just put it in line with the control wire from the head unit - so when the unit tells it to go up, it goes up til you turn the switch off. The alternative is to take the unit apart and cut the plastic toothed snake that is inside the antenna. Make it to your desired length. Why bother to fuck with it? Just leave it alone & if you're really hurting for something to do then read a book or play chess on your computer. Is this OCD or what? BTDT. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) Why play chess or read a book when you can fuck with your car? Thanks for yet another pointless comment. You're most welcome. My experience, although limited, it that most modern cheap power antennas can't be opened & modified. You might want to go with a shorter focal length lens to open up your field of view. Watch out for barrel distortion if you're shooting skyscrapers. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
Lo-Fi Version | Time is now: 18th September 2024 - 07:05 PM |
