I know another oil question, Amsoil vs VR1 vs Driven |
mb911 |
Apr 7 2024, 02:06 PM
914 Guru Group: Members Posts: 7,149 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I use to run amsoil z rod and I liked it but very expensive
Currently running vr1 but I keep hearing about driven . Driven is also expensive. Is it over thinking this for driving a few thousand miles a year and changing every season? |
technicalninja |
Jul 18 2024, 09:09 AM
Senior Member Group: Members Posts: 1,825 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Cheaper high zinc oils still costs $100 ish. I use high quality filters, drive about 1000 miles per year and change the oil once a year so over thinking it on my end. It’s getting a second change this year as tuning this year it burned extra rich early on in the process so need to change that oil out. Bottom line - you’re guessing and making assumptions. $35 for an oil analysis gets you real data on fuel and moisture contamination (if any) plus info on metals contamination. With that data and a baseline, you can make intelligent decisions rather than just dumping oil for the sake of it. Otherwise it’s all voodoo religion / oil mythology much of which is no longer relevant with modern oil stock and additive packages. Just sayin’ (IMG:style_emoticons/default/beerchug.gif) Clip from my Jeep maintenance notes: Practicing what I preach. Looks good EXCEPT for the DORMAN part! I don't use Dorman if it has moving parts or electronics... Some of their "Fix It" setups are world class. Their electrical crap is Chinese! After you spend money AND have pissed off customers you stop using Chinese stuff... Chinese parts have cost me OVER 10K during the pandemic as I could NOT buy OEM. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:20 PM |
