Blinking Parking Brake Light. |
Olympic 914 |
Jul 3 2024, 08:32 AM
Group: Members Posts: 1,699 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Out running errands and when leaving I noticed the brake light blinking. I do use the parking brake a lot. so I pulled it on and off a couple times, no change. The brakes feel normal. Stopped for gas and checked the fluid reservoir, its at the proper level.
Then driving home, after a couple miles the light went off. (?) When I got home it was back on again. I am thinking maybe a wonky parking brake switch. But will check the switch on the master also Is the parking brake switch a Normal Open or Normal Closed? Anyone else have this happen ? Or know of something else I should check.... |
Lucky9146 |
Jul 18 2024, 10:06 AM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,641 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
@Dave_Darling
I like the sound of this "you need to press the reset button on the switch on the side of the master cylinder." You mean there is a reset button on the side of the brake light switch? Right? Hmmm not seeing it? (IMG:style_emoticons/default/idea.gif) Not trying to be a wise guy. Don't get me wrong, I want to press a reset button so bad. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) Pelican offering and switch installed 2 pole And a glimpse of the switch on a 914 Master Pictured on 914 is single pole, and I just looked at a 914 switch that I have and it does have a reset button. Any other suggestions please. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:08 PM |
