Charles Freeborn |
Member ![]() ![]() Group: Members Posts: 276 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest ![]() |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,477 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
If one came out on its own, I wouldn't trust any of them...
You've got three to do in that picture and one is at a serious angle! I'd pull it. I learned (on Italian junk) to NEVER trust swagged in passage plugs. Every Alfa engine I've been into had MISSING welch plugs in the crank! Adding plugs in the Alfa cranks has always included a rebalance. Normal method to repair for me has been carefully tap for a pipe plug. I'd add air pressure behind the missing plug to not allow shavings into engine. Did you notice oil pressure? It's possible a stuck pressure relief valve over pressurized it. I once had a Honda engine that was BLOWING oil filters OFF the engine. It PEGGED a 300psi gauge. It was quite messy... |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:28 AM |
