Fun, Not Fun, Fuel hose |
NARP74 |
Jul 20 2024, 08:44 AM
Senior Member Group: Members Posts: 1,172 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
For a 3.2 conversion that I was trying to bring out to a meetup on Sunday. Relocating my fuel pump to a better up front location, under the steering rack. Redoing some of the hose connections to make them longer. 8mm, 10mm for most of them from the tank and the supply and return lines in the car.
The Bosch fuel pump I have needs 12mm, maybe 13mm to get over the bulge. I have; 5/16 hose which is 7.8mm, good enough for the 8mm connections. 3/8 which is 9.5mm, good enough for the 10mm connections. I tried everything to get the 3/8 to stretch over the 12/13 mm needed to install on the feed side of the fuel pump. I tried heating in the sun on a black car, lazy way. Then I tried a heat gun. Then I tried needle nose pliers to stretch the hose opening out. Tried alcohol to slip it over. Nothing I did would get more than a 1/4 over the fuel pump inlet and then it would bunch up and not budge any further. Then I went to the store and bought some 1/2 inch which is 12.7mm. Fits great over the Bosch fuel pump, but is too sloppy over the 10mm supply line from the tank. And I don't have a fuel hose clamp that big yet. What's an idiot to do? I spent a day on this and am not much further along and I still need to wire it! All of the hose is the good stuff from NAPA, Gates Barricade for fuel injection. Help |
technicalninja |
Jul 22 2024, 09:09 AM
Senior Member Group: Members Posts: 1,825 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
@rjames I do not have a filter before the pump, only the sock in the tank. One of the local suggestions was a WIX 33274. Roughly 10mm on one side and 12mm on the other. Filter and adapter both. The hose I am trying to use is only 10 inches from the tank to the pump. I will see if I can fit the filter inline there and make it work somehow. @technicalninja one of my first stops was the adapter page for Tangerine. He does not have a 10mm to 12mm adapter yet. Maybe we can show him the need for one. Get the 33274 and one of my adapters. I use 1/2" FI hose or race hose for the 12mm fittings between filter and pump. You figured it OUT on post number 8. I said "Hell yes! easy button" on post 9 And then Chris Foley advised to use same filter... He thought you were going down to 8mm and would ALSO need his little adaptor. Many have been confused by the 10 X 12 numbers and the little square filter r-towle posted would get the 8 X 12 that most posters got stuck in their brain! To me it sounds like the WIX 33274 will work fine for your application. I am in agreement with SH about being stuck on an old Bosch pump... Why? |
Lo-Fi Version | Time is now: 18th September 2024 - 07:07 PM |
