Blinking Parking Brake Light. |
Olympic 914 |
Jul 3 2024, 08:32 AM
Group: Members Posts: 1,699 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Out running errands and when leaving I noticed the brake light blinking. I do use the parking brake a lot. so I pulled it on and off a couple times, no change. The brakes feel normal. Stopped for gas and checked the fluid reservoir, its at the proper level.
Then driving home, after a couple miles the light went off. (?) When I got home it was back on again. I am thinking maybe a wonky parking brake switch. But will check the switch on the master also Is the parking brake switch a Normal Open or Normal Closed? Anyone else have this happen ? Or know of something else I should check.... |
burlybryan |
Jul 23 2024, 09:00 AM
Member Group: Members Posts: 117 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
Just to add a some anecdotal experience from a similar issue. The light plus click is usually the MC switch. I had to replace my switch to make that go away.
I had an additional issue where my cars parking brake relay would click non-stop. The light flashed as normal when the parking brake was engaged, but the clicking remained when disengaged. I checked all the grounds in the cabin and what I eventually discovered was a weak front turn signal bulb contact. The clicking was an indication of a poor ground or poor electrical contact "somewhere" - you just have to go on the easter egg hunt to find it. |
Lo-Fi Version | Time is now: 18th September 2024 - 06:57 PM |
