> How to wire up an early 911 turn signal switch into a 914-4 harness, For MB911 - Your 12 step program.
ClayPerrine
post May 8 2020, 03:00 PM
Step 1. Buy these:
1980 Porsche 911SC Female Housing, 14 Pin
1983 Porsche 911SC Pin, Female 14 Pin Connector (you need 14 of these)
1969 Porsche 911 Lid, 14 Pin Plug
1969 Porsche 911 14 Pin Plug Male Kit
Why Porsche chose to provide a kit for the Male plug, but make you purchase all of the pieces for the female connector separately we will never know.
2. Remove the connectors from the ends of the wires on the turn signal switch. Don't remove the one on the switch end Brown/White wire. That connects to the back of the horn wiper ring.
3. Strip the insulation off the wires, and solder on the pins for the MALE connector. You don't want to use the female end, because some of those wires can be hot with 12v if you use the male connector on the chassis harness side.
4. Put the pins into the bottom of the male connector. Make notes of the wire color associated with each pin number.
5. Install the top on the connector.
6. Remove the beam relay and disconnect the wires. There is a large yellow wire and a small yellow wire. Strip and solder on female pins to the large yellow, white and red/white wires. The small yellow wire is not going to be used.
7. Remove the plug that connects to the turn signal/wiper switches. The wires that connected to the wiper switch are not going to be used any more.
Note: I like to take the time to completely remove the wires from the harness, but it is OK to leave them there. Just tape them off so they don't short anything.
8. Strip and solder the remaining female pins onto the brown/white, black/white, black/white/green, black/green, grey/red, grey/brown, grey, and red.white wires.
9. Install the female pins into the female connector base. Make sure you match the connections with the wires in the male connector. I like to put the female base on the male connector and install the pins to match.
10. Install the cover on the female connector.
11. Test the wiring. Make sure the turn signals work, the low and high beams work and make sure the park light lights on one side with the key off and the turn signal engaged.
12. Last and most important step. Have a beer and celebrate!
Here is a chart of the wire connections for your reference.
mb911
post Jun 27 2024, 10:18 AM
Yup mine is all good. Ironically it was just the electrical portion of the switch
morehills
post Jun 27 2024, 05:02 PM
QUOTE(mb911 @ Jun 27 2024, 10:18 AM) *
I think my problem is that that combination flasher (1971) is still in the path of the high and low beam wires. I think I need to eliminate this as the 911 switch works without a flasher.
mb911
post Jun 28 2024, 05:12 AM
QUOTE(morehills @ Jun 27 2024, 03:02 PM) *
Correct
morehills
post Jul 24 2024, 12:59 PM
QUOTE(mb911 @ Jun 28 2024, 05:12 AM) *
Correct
I've been away and finally got back to sorting this.
I pulled the 914 combination flasher out of the path. That was definitely a problem with the 911 column switch. Now I have low beams, and I can engage the high beams when I pull back on the stalk towards me (flasher mode) and hold it. But I can't get the high beams to engage in the forward position of the stalk. I'm not sure which forward spot is for high beams, but nonetheless, both positions are now low beams. Any ideas what I may have done wrong? The headlight wires are routed correctly from the column and I've spent hours pouring over the wiring diagrams. Could the headlight relays be at fault? Not sure why they would work in one position and not another.
Does anyone have suggestions for how I test this to determine where the problem might be?
Thanks for any help. This has been a bit of a saga but I'm close to closing up the dash and moving on.
John
ClayPerrine   How to wire up an early 911 turn signal switch into a 914-4 harness   May 8 2020, 03:00 PM
mb911   Thanks so much.. Its on order.. Still have to figu...   May 8 2020, 03:48 PM
ClayPerrine   Thanks so much.. Its on order.. Still have to fig...   May 8 2020, 05:22 PM
ClayPerrine   And if you run into any problems with the wiring, ...   May 8 2020, 05:23 PM
mb911   Sounds good.. Thanks   May 8 2020, 05:35 PM
GregAmy   What's the advantage of the 911 one?   May 9 2020, 10:52 AM
mb911   What's the advantage of the 911 one? Left ...   May 9 2020, 10:55 AM
mb911   @ClayPerrine my beam relay has a yellow with Red ...   May 10 2020, 01:37 PM
ClayPerrine   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 10 2020, 07:00 PM
mb911   So this bundle of wires won't get used?   May 13 2020, 07:20 PM
ClayPerrine   So this bundle of wires won't get used? N...   May 14 2020, 07:40 AM
mb911   This is harness side and must have plugged into th...   May 14 2020, 01:32 PM
ClayPerrine   This is harness side and must have plugged into t...   May 15 2020, 12:14 PM
mepstein   Thank you Clay :beer2:   May 15 2020, 01:57 PM
mb911   Ok done and done meaning soldered ends, had a beer...   May 16 2020, 06:08 PM
mb911   Well plot thickens.. Found out the yellow wire was...   May 16 2020, 08:35 PM
mb911   Problem semi solved.. Was not getting 12v to the y...   May 17 2020, 01:45 PM
ClayPerrine   Ben, I haven't forgotten about you. I spent t...   May 18 2020, 04:38 AM
ClayPerrine   Ben, Do you have low beams? Do you have park ...   May 20 2020, 06:54 PM
mb911   Ben, Do you have low beams? Do you have park...   May 21 2020, 06:57 AM
ClayPerrine   Ben, Do you have low beams? Do you have par...   May 21 2020, 11:32 AM
mb911   [quote name='mb911' post='2817451' date='May 21 2...   May 21 2020, 12:21 PM
ClayPerrine   [quote name='mb911' post='2817451' date='May 21 ...   May 21 2020, 12:25 PM
Mark Henry   Thanks Clay bookmarked this thread. I think I hav...   May 20 2020, 09:25 PM
mb911   I am still suspicious that the 911 ignition switch...   May 21 2020, 12:36 PM
mb911   @superhawk996   Nov 15 2020, 05:37 PM
morehills   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jun 27 2024, 08:50 AM
mb911   Yup mine is all good. Ironically it was just the e...   Jun 27 2024, 10:18 AM
morehills   Yup mine is all good. Ironically it was just the ...   Jun 27 2024, 05:02 PM
mb911   Yup mine is all good. Ironically it was just the...   Jun 28 2024, 05:12 AM
morehills   [quote name='morehills' post='3153516' date='Jun ...   Jul 24 2024, 12:59 PM
- Lo-Fi Version Time is now: 14th December 2025 - 05:19 AM
