Tear Down and Reassemble Unstarted 1.7 built to 2270, 1.7 to 2270 Unstarted 10 Year Old Build |
Robroe |
Jul 23 2024, 06:04 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Moved from topic of first start of 10 year old build to tear down, inspect and reassemble. The 10 year old build is from a 73 1.7 to a 2270. Stroked to 78 mm and 96 mm cylinder diameter. Heads are Ham/RAT with 36 mm exhaust and 44 mm intake. Both are nicely ported.
Have torn it down to the case and checking crank end play before I split the case and pull the cam and crank. So far, everything is new and looks in good order. I'm concerned about oil passages being blocked with old assembly lube so a complete tear down and reassemble is happening. Discovered stacked cylinder spacers (4) totaling .150". So looking to replace those with single spacers. So far I can only find .160" spacers from type 4 store and may just use them as impact on compression appears minimal. Was shocked to discover crank end play is .450"! Sure glad I didn't try to start this thing. Will check again in the morning to make sure I'm checking it correctly, but I'm doing the same thing on the videos such as Ian Carrs YouTube engine builds so pretty sure I'm checking it correctly. Now to figure out what to do about that huge end play. Any thoughts about what to watch out for? |
Superhawk996 |
Jul 25 2024, 06:18 AM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
.045” of crank end play sounds like there are no shims there. 0.045” is excessive and about 10x the spec.
Shims are behind the flywheel. If you’ve removed the flywheel, were there 3 shims between flywheel and end of the main bearing? Look closely - they can be stuck to the bearing with oil and obscured by the rear main seal. Note: there must be 3, and only 3 shims used at reassembly to set crank endplay. Cross that bridge later but you need to be aware of this. |
Lo-Fi Version | Time is now: 18th September 2024 - 06:59 PM |
