Door not closing, Door latch is not grabbing post |
Deusexmachina77 |
Jul 25 2024, 06:52 AM
Member Group: Members Posts: 96 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
My driver-side door stopped working.
I've checked alignment, and that doesn't seem to be the issue. When I compare it to the passenger-side door, the latch mechanism doesn't have the same tension as the passenger-side. I'm not sure how to describe it other than it has lost its oomph. It moves, but it is soft and has no tension. I can close the door, but it doesn't catch all the way. Another shove secures it. Is it as simple as needing some lubrication? Or is there a spring that broke? I haven't taken it apart yet. I'm trying to avoid a search-and-destroy mission and get guidance before disassembling. Thanks, Victor |
dr914@autoatlanta.com |
Jul 25 2024, 09:42 AM
914 Guru Group: Members Posts: 8,044 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
sounds like you need to remove the catching mechanism inside the door and clean it, and then reinstall. it is not releasing all of the way because it is sticking resulting in the door not latching
My driver-side door stopped working. I've checked alignment, and that doesn't seem to be the issue. When I compare it to the passenger-side door, the latch mechanism doesn't have the same tension as the passenger-side. I'm not sure how to describe it other than it has lost its oomph. It moves, but it is soft and has no tension. I can close the door, but it doesn't catch all the way. Another shove secures it. Is it as simple as needing some lubrication? Or is there a spring that broke? I haven't taken it apart yet. I'm trying to avoid a search-and-destroy mission and get guidance before disassembling. Thanks, Victor |
Deusexmachina77 |
Jul 25 2024, 03:49 PM
bdstone914 |
Jul 25 2024, 10:19 PM
bdstone914 Group: Members Posts: 4,658 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Deusexmachina77
I have extra drivers latches that have been cleaned and replated. Note the different spring length. I dont know why they did this. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th September 2024 - 06:54 PM |
