Tear Down and Reassemble Unstarted 1.7 built to 2270, 1.7 to 2270 Unstarted 10 Year Old Build |
Robroe |
Jul 23 2024, 06:04 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Moved from topic of first start of 10 year old build to tear down, inspect and reassemble. The 10 year old build is from a 73 1.7 to a 2270. Stroked to 78 mm and 96 mm cylinder diameter. Heads are Ham/RAT with 36 mm exhaust and 44 mm intake. Both are nicely ported.
Have torn it down to the case and checking crank end play before I split the case and pull the cam and crank. So far, everything is new and looks in good order. I'm concerned about oil passages being blocked with old assembly lube so a complete tear down and reassemble is happening. Discovered stacked cylinder spacers (4) totaling .150". So looking to replace those with single spacers. So far I can only find .160" spacers from type 4 store and may just use them as impact on compression appears minimal. Was shocked to discover crank end play is .450"! Sure glad I didn't try to start this thing. Will check again in the morning to make sure I'm checking it correctly, but I'm doing the same thing on the videos such as Ian Carrs YouTube engine builds so pretty sure I'm checking it correctly. Now to figure out what to do about that huge end play. Any thoughts about what to watch out for? |
technicalninja |
Jul 26 2024, 10:57 AM
Senior Member Group: Members Posts: 1,825 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Oops!
Sorry for the insult! If you could see it that's BAD! I'm a believer in setting end play with rear main seal OUT and no 0-ring. Those can skew results. Seals and O-ring at final assembly only. Pick those little bearing dowels out. Those puppies will FALL out and you'll be hunting them. When I take stuff down I re-install ALL of the hardware exactly as I removed it. My cases have every single fastener in them. Crap that I cannot affix I'll have in a small freezer zip lock bag. If you label the bag first with a Sharpie 20 years from now it will still make sense... Do it that way and you don't have to remember SHIT! (IMG:style_emoticons/default/ninja.gif) |
Lo-Fi Version | Time is now: 18th September 2024 - 06:52 PM |
