At TDC #1 but... |
At TDC #1 but... |
Literati914 |
Jul 26 2024, 06:57 PM
Senior Member Group: Members Posts: 1,651 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
On a freshly built but never installed, never ran.. oil never added and sitting for years 1.7L engine: I've verified TDC @ #1 but the rotor tip is showing 180 deg. out.
Is that just a matter of loosening a bolt and rotating it to face towards the driver's seat (apprx).. or is it gonna be more of a 'pull the distributor and re-clock the gear down in the bore' ? . |
technicalninja |
Jul 26 2024, 07:38 PM
Senior Member Group: Members Posts: 1,825 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
It's .006 and or .008 depending on year.
For an initial run in, first start up I'd just run .008 especially if I didn't hand lap the valves. You should EXPECT at least .001 initial tighten up on un-lapped valves. Do a good lap job and you WILL NOT see initial wear... |
Lo-Fi Version | Time is now: 18th September 2024 - 07:15 PM |
