Tear Down and Reassemble Unstarted 1.7 built to 2270, 1.7 to 2270 Unstarted 10 Year Old Build |
Robroe |
Jul 23 2024, 06:04 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Moved from topic of first start of 10 year old build to tear down, inspect and reassemble. The 10 year old build is from a 73 1.7 to a 2270. Stroked to 78 mm and 96 mm cylinder diameter. Heads are Ham/RAT with 36 mm exhaust and 44 mm intake. Both are nicely ported.
Have torn it down to the case and checking crank end play before I split the case and pull the cam and crank. So far, everything is new and looks in good order. I'm concerned about oil passages being blocked with old assembly lube so a complete tear down and reassemble is happening. Discovered stacked cylinder spacers (4) totaling .150". So looking to replace those with single spacers. So far I can only find .160" spacers from type 4 store and may just use them as impact on compression appears minimal. Was shocked to discover crank end play is .450"! Sure glad I didn't try to start this thing. Will check again in the morning to make sure I'm checking it correctly, but I'm doing the same thing on the videos such as Ian Carrs YouTube engine builds so pretty sure I'm checking it correctly. Now to figure out what to do about that huge end play. Any thoughts about what to watch out for? |
Jack Standz |
Jul 26 2024, 09:50 PM
Member Group: Members Posts: 363 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
A few times in that vid you can see big ass holes (3/4"?) in the "oil towers" on all of the cases. He doesn't say shit about them. I'm thinking crankcase ventilation but. "Inquiring minds want to know..." What do you think @Superhawk996 Agree with you. They are probably crankcase ventilation. We're running only an -AN 12 line from the oil tower to a catch can with no vents at the valve covers in a 2056 with no problems so far. Didn't we have this conversation before? (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 18th September 2024 - 06:52 PM |
