Fuel starve, or something |
arsprod |
Jul 26 2024, 02:56 PM
Member Group: Members Posts: 210 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
Teeners,
I swapped out the single carb that came with my 74 2.0 for new to me dual Weber 40's. It took a bit to get them jetted and adjusted but it's at least very close. The car runs great - and then it doesn't. With no consistency, it will start to stumble, cough, and backfire. Most of the time it works itself out though seems to be getting worse. I'm befuddled. (IMG:style_emoticons/default/confused24.gif) Here's what I know: - carbs are jetted main 145, air 200, idle 65, venturi 28 - plugs look ok, if anything rich - I don't seem to have any vacuum leaks - steady 3psi fuel pressure - timing and valves adjusted - new plugs Help! thanks Aaron |
rhodyguy |
Jul 27 2024, 06:29 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Turn one idle speed adj screw in increasing the idle pretty high. Leave the other ISAS alone. Now measure the flow too see how closely they match. The 009 will work but the system is not optimized. Are points inside of the distr or something solid state? Any sort of snapping or popping back thru a carb?
arsprod |
Jul 28 2024, 12:53 PM
Turn one idle speed adj screw in increasing the idle pretty high. Leave the other ISAS alone. Now measure the flow too see how closely they match. The 009 will work but the system is not optimized. Are points inside of the distr or something solid state? Any sort of snapping or popping back thru a carb? OK, did that - other carb is within 3 ticks of the fast idle one. What does that tell me? It's points, and yes getting snapping and popping through carb. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:13 PM |
