Fuel starve, or something |
arsprod |
Jul 26 2024, 02:56 PM
Member Group: Members Posts: 210 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
Teeners,
I swapped out the single carb that came with my 74 2.0 for new to me dual Weber 40's. It took a bit to get them jetted and adjusted but it's at least very close. The car runs great - and then it doesn't. With no consistency, it will start to stumble, cough, and backfire. Most of the time it works itself out though seems to be getting worse. I'm befuddled. (IMG:style_emoticons/default/confused24.gif) Here's what I know: - carbs are jetted main 145, air 200, idle 65, venturi 28 - plugs look ok, if anything rich - I don't seem to have any vacuum leaks - steady 3psi fuel pressure - timing and valves adjusted - new plugs Help! thanks Aaron |
rhodyguy |
Jul 28 2024, 02:35 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I’m not familiar with 3 ticks. Of what? You mean a snail gauge and one carb reads 6 and the other 3? Snapping back on the lower reading carb?
Lo-Fi Version | Time is now: 18th September 2024 - 07:21 PM |
