> Question for 914/6 oil tank/oil change, Does it need a supplemental way to drain?
Krieger
post Dec 16 2011, 12:46 AM
I have seen some of the members here adding ways to drain the oil tank. 911s have a tank drain, but their tanks are mounted fairly low in relation to the engine. The bottom of the 6 tank is close to being near the same height as the top of the engine caes. Won't the oil just run into the engine case?
930cabman
post Jul 29 2024, 06:30 AM
After draining the oil from the sump (and getting 10 qts) and later opening up the line to the oil cooler, I collected less than 1/2 quart.
Is it worth it to insert a "T" fitting for less than 1/2 qt?
My gut says no, leave well enough alone
Krieger   Question for 914/6 oil tank/oil change   Dec 16 2011, 12:46 AM
ArtechnikA   911's and 914.6 have a drain plug in the botto...   Dec 16 2011, 05:02 AM
Krieger   Thanks for this very helpful info One of the memer...   Dec 16 2011, 12:14 PM
ArtechnikA   Thanks for this very helpful info One of the meme...   Dec 16 2011, 01:01 PM
930cabman   Thanks for this very helpful info One of the meme...   Jul 9 2024, 04:54 PM
brant   I chickened out on the T-drain idea when I built t...   Dec 16 2011, 01:15 PM
Krieger   I was planning on drilling the cap for a safety wi...   Dec 16 2011, 01:22 PM
Cap'n Krusty   I have seen some of the members here adding ways ...   Dec 16 2011, 02:02 PM
Krieger   I will be using two metric to an adapters at the t...   Dec 16 2011, 04:29 PM
ArtechnikA   because there are two separate oil systems in a 91...   Dec 16 2011, 05:06 PM
J P Stein   because there are two separate oil systems in a 9...   Dec 16 2011, 05:20 PM
rfuerst911sc   It may not need to have it but having one makes it...   Dec 17 2011, 04:45 AM
mb911   I did this for mine   Jul 9 2024, 05:14 PM
930cabman   I did this for mine Looks slick, no interferenc...   Jul 9 2024, 05:35 PM
mb911   I did this for mine Looks slick, no interferen...   Jul 9 2024, 05:47 PM
Krieger   This is the solution I came up with. I ordered the...   Jul 9 2024, 07:38 PM
930cabman   This is the solution I came up with. I ordered th...   Jul 10 2024, 01:02 PM
Krieger   I am very happy I did this. It drains very quicky...   Jul 9 2024, 07:43 PM
brant   I am very happy I did this. It drains very quick...   Jul 9 2024, 08:17 PM
ClayPerrine   I am very happy I did this. It drains very quic...   Jul 28 2024, 10:07 AM
gereed75   [quote name='brant' post='3155695' date='Jul 9 20...   Jul 28 2024, 10:51 AM
porschetub   I am very happy I did this. It drains very quick...   Jul 10 2024, 04:12 PM
Krieger   @brant I bought the oil lines from a major suppl...   Jul 9 2024, 11:17 PM
Biggles   I have seen some of the members here adding ways ...   Jul 10 2024, 02:12 AM
930cabman   Curious: just how much oil is left in the system ...   Jul 28 2024, 07:26 AM
mb911   Curious: just how much oil is left in the system...   Jul 28 2024, 08:46 AM
930cabman   Curious: just how much oil is left in the syste...   Jul 28 2024, 09:13 AM
930cabman   After draining the oil from the sump (and getting ...   Jul 29 2024, 06:30 AM
- Lo-Fi Version Time is now: 5th February 2025 - 05:45 AM
