Tear Down and Reassemble Unstarted 1.7 built to 2270, 1.7 to 2270 Unstarted 10 Year Old Build |
Robroe |
Jul 23 2024, 06:04 PM
Member Group: Members Posts: 76 Joined: 10-August 21 From: Wenatchee, WA Member No.: 25,793 Region Association: Pacific Northwest |
Moved from topic of first start of 10 year old build to tear down, inspect and reassemble. The 10 year old build is from a 73 1.7 to a 2270. Stroked to 78 mm and 96 mm cylinder diameter. Heads are Ham/RAT with 36 mm exhaust and 44 mm intake. Both are nicely ported.
Have torn it down to the case and checking crank end play before I split the case and pull the cam and crank. So far, everything is new and looks in good order. I'm concerned about oil passages being blocked with old assembly lube so a complete tear down and reassemble is happening. Discovered stacked cylinder spacers (4) totaling .150". So looking to replace those with single spacers. So far I can only find .160" spacers from type 4 store and may just use them as impact on compression appears minimal. Was shocked to discover crank end play is .450"! Sure glad I didn't try to start this thing. Will check again in the morning to make sure I'm checking it correctly, but I'm doing the same thing on the videos such as Ian Carrs YouTube engine builds so pretty sure I'm checking it correctly. Now to figure out what to do about that huge end play. Any thoughts about what to watch out for? |
Jack Standz |
Jul 31 2024, 03:35 PM
Member Group: Members Posts: 363 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
If you’re going to use that T1 pump, you need to measure the OD of the pump vs the ID of the case. T1 pumps are notoriously undersized and create internal leakage and oil aeration. I’d also measure the gears. 26mm or 30mm? (Length) 30mm will cause issues unless you are running an external oil cooler, thermostat, and lines to the front of vehicle. Too much pressure and flow just internally bypasses at the pressure relief valve, causes oil cooler seal weeps/leaks and can cause overheating due to OEM oil cooler bypassing. 26 mm gears. Thanks. Will check pump case fit dimension. Using OEM cooler. Another option is to get an oil pump from Gene Berg that is hard anodized with an o-ring for a groove between the pump and case. BTW there is an unusual hole in the pressure side of the pump between the pump and the cover plate. Anyone have a guess what it is there for? Can't tell if there are changes to the route of the oil pathway to smooth or straightened out the oil's travel so there's aren't a sharp turn on the way out of the pump into the case?? |
Lo-Fi Version | Time is now: 18th September 2024 - 07:18 PM |
