Seat removal, How to |
74ravenna |
Nov 15 2015, 12:07 PM
Member Group: Members Posts: 472 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
I hate to ask because it should be pretty straight forward and I've searched the site for an explanation but couldn't find one.
So, what is the process for seat removal? The bolts at the rear of the track are easy enough to access but what about the forward bolts? Or does the seat slide out of the tracks somehow? I just need to access the wiring and do a little cleaning (surface rust removal) of the floor. Thanks in advance. |
doug_b_928 |
Aug 10 2024, 08:28 PM
Senior Member Group: Members Posts: 712 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
The silver brackets (one of which has the black handled seat adjuster) are independently bolted to the seat base so you should be able to just remove the seat and reverse the two silver brackets from that seat (i.e., switch them to opposite sides of the same seat). To check if you actually have two of the same side seats feel for the larger indentation on the driver’s seat which is a relief for the ebrake handle) and see if it’s just as big on the passenger seat (which would indicate that you have two driver’s seats). But I’m guessing a PO just put the silver tails on backwards on one of the seats.
jbyron |
Aug 12 2024, 08:11 AM
Jamie Group: Members Posts: 155 Joined: 17-July 07 From: Ballwin, MO Member No.: 7,916 Region Association: Upper MidWest |
The silver brackets (one of which has the black handled seat adjuster) are independently bolted to the seat base so you should be able to just remove the seat and reverse the two silver brackets from that seat (i.e., switch them to opposite sides of the same seat). To check if you actually have two of the same side seats feel for the larger indentation on the driver’s seat which is a relief for the ebrake handle) and see if it’s just as big on the passenger seat (which would indicate that you have two driver’s seats). But I’m guessing a PO just put the silver tails on backwards on one of the seats. Tried swapping the silver brackets, but couldn't get the seat to go back on the rails. The metal prong that catches on the release spring interferes with the seat adjuster. Definitely have two passenger seats - no e-brake indentation. Ordering a replacement seat bracket for the driver's side. |
Lo-Fi Version | Time is now: 6th January 2025 - 05:37 PM |
