Accelerator cable not translating pedal movement to carb action |
Tdskip |
Aug 24 2024, 12:31 PM
Advanced Member Group: Members Posts: 3,702 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hope everybody is having a good weekend and thanks in advance for any thoughts or suggestions.
I have it should be an easy problem to solve that I haven’t solved – I believe the accelerator cable that came in this project is simply too long because when the gas pedal is pressed the cable flexes to a point where the physical motion from the gas pedal doesn’t translate to the same pull on the carb linkage. In other words, the cable moves around enough that it doesn’t effectively pull the carburetor linkage to increase power. I have a replacement cable, but before I go through that I wanted to ask to see if there’s something that maybe other people encountered or that comes to mind that I’m missing. Cable has the red arrows pointing to it. Thanks! |
76-914 |
Aug 24 2024, 03:12 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,646 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I would strap the cable down so it cannot flop around. Next I would clamp the cable with some vice grips at the point it exits the sheath. If your pedal moves any after that then something wonky is going on with the cable or the conduit it resides in. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 22nd December 2024 - 12:57 AM |
