> Solvent HELP, Cannot find solvent to dissolve adhesive
Gatornapper
post Sep 3 2024, 06:31 PM
I love the black leather Dino steering wheel that is on my 944 S.
I want to put it on my 914.
So I got a tan Dino steering wheel to go in my 944 S that has a tan interior.
One problem - I can find no solvent to remove the adhesive from the new tan steering wheel. It had clear plastic protecting the chrome which pulled off easily. But I can find no solvent to dissolve the adhesive that held the clear plastic on.
I have tried gasoline, strong carb cleaner, brake cleaner, acetone, lacquer thinner, WD-40,
Seafoam, and even Super Glue Remover.
I can't take the nice wheel out of the 944 S until the new one can go in.
HELP. Looking for advice on a solvent that will dissolve this adhesive.
Pics below - many thanks to all suggestions.
GN
(IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1725409879.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1725409879.2.JPG)
Ishley
post Sep 3 2024, 09:20 PM
Toluene is a good chemical to clean adhesives. You can also try heat from a heat
Gun. Slowly heat the area and be careful not to damage anything. Most glues and epoxies will breakdown with heat.
Gatornapper   Solvent HELP   Sep 3 2024, 06:31 PM
JeffBowlsby   Tried Goof Off? Or Goo Gone? They seem to be a mi...   Sep 3 2024, 06:38 PM
Gatornapper   Jeff - My BAD. Yes I did. Didn't touch it. ...   Sep 3 2024, 07:00 PM
technicalninja   Another member found the orange citrus hand cleane...   Sep 3 2024, 06:48 PM
Gatornapper   Great idea! Have some on hand - will try it...   Sep 3 2024, 07:01 PM
IronHillRestorations   Denatured alcohol? Lighter fluid? Acetone? The h...   Sep 3 2024, 07:19 PM
Gatornapper   Acetone did'nt touch it. The Citris seemed to...   Sep 3 2024, 07:31 PM
dhuckabay   Have had good luck with Xylol or Xylene, one in th...   Sep 3 2024, 07:21 PM
Spoke   I use naphtha to dissolve glue.   Sep 3 2024, 07:36 PM
bkrantz   3M Adhesive Remover. (adhesive remover is right i...   Sep 3 2024, 08:23 PM
Gatornapper   Might I find this at Advance Auto or Autozone? Th...   Sep 4 2024, 07:01 AM
bkrantz   Might I find this at Advance Auto or Autozone? T...   Sep 4 2024, 08:13 PM
KELTY360   I’ve used lighter fluid with success. Good luck ...   Sep 3 2024, 08:35 PM
worn   I’ve used lighter fluid with success. Good luck...   Sep 3 2024, 09:18 PM
Ishley   Toluene is a good chemical to clean adhesives. Yo...   Sep 3 2024, 09:20 PM
Superhawk996   If it were me, I would contact seller and/or manuf...   Sep 3 2024, 10:15 PM
Gatornapper   First thing I did was ask seller - he was clueless...   Sep 4 2024, 07:00 AM
windforfun   If it were me, I would contact seller and/or manu...   Sep 4 2024, 11:12 AM
krazykonrad   3M Adhesive Remover. (adhesive remover is right ...   Sep 4 2024, 07:03 AM
technicalninja   Sorry bout the pumice! Often times heat can h...   Sep 4 2024, 08:24 AM
76-914   https://www.amazon.com/3M-03618-Adhesive-Re...z/dp...   Sep 4 2024, 08:42 AM
dr914@autoatlanta.com   3m makes commercial body shop adhesive remover. Y...   Sep 4 2024, 08:54 AM
mgphoto   Small amount of gasoline, on a rag, avoiding the s...   Sep 4 2024, 09:43 AM
mxkinn01   One more vote for "lighter fuel" not lig...   Sep 4 2024, 09:52 AM
krazykonrad   Might I find this at Advance Auto or Autozone? T...   Sep 4 2024, 11:27 AM
douglastic   Is it truly chrome? Or polished metal? Maybe aband...   Sep 4 2024, 12:11 PM
live free & drive   Try Turtle wax sticker and label remover - I found...   Sep 4 2024, 12:14 PM
MikeK   My go to is slow reducer. Takes much longer to ev...   Sep 5 2024, 10:29 AM
GregAmy   Are you certain that this is just residual adhesiv...   Sep 5 2024, 10:43 AM
914sgofast2   Have you tried Simple Green cleaner? Put some on t...   Sep 5 2024, 10:45 AM
TheCabinetmaker   Acetone, lacquer thinner, MEK, dissolves the stro...   Sep 6 2024, 08:55 AM
930cabman   Acetone, lacquer thinner, MEK, dissolves the str...   Sep 8 2024, 04:57 PM
TheCabinetmaker   Acetone, lacquer thinner, MEK, dissolves the stro...   Sep 6 2024, 08:57 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 2nd January 2025 - 09:20 AM
